hey all, went down the street locked car ,went inside s**t left mobile phone in car go to car no joy wont open even tried the key,perfectly fine 3 minutes before anyone got any ideas?::
thats the problem with holden keys once they wear down a little they wont open your door. if the remotes not working then the car might not have any power(probably a loose battery terminal)if this is the case get some jumper leads hook the positive upto the starter motor
(the thickest lead running into it) and the other to the chassis then to another battery or car and this should give you enough power to open the door via remote
this is a VL?
If so why can't you get into it? try a paddle pop stick!!
nah not a vl if it was my daughter could break into it,cracked it this morning threw keys in disgust guess what ? they now work still the key doesn,t lock or unlock the car
