Results 1 to 15 of 15
Thread: radiator, again
    VT Acclaim Wagon
    Oct 2008
    Default radiator, again
    I just now spoke to a radiator specialist about replacing my radiator, tranny cooler leaking trans oil into the radiator water. He told me all the bits I already knew but then said I should check for electrical current as well as it causes leaks. what???
    96 VS II Acclaim
    Dec 2007
    VT Acclaim Wagon
    Oct 2008
    I understand electrolysis between disimilar metals ie cast iron and aluminium but I thought that that only affected heads and blocks of aluminium head motors. Also thought that seeing how water is not a good conductor of electricity plus the radiator hoses are rubber or neoprene or silicone, all good insulators, the radiator would be isolated from the rest of the car. Apparently not?
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Electrolysis affects aluminium radiators really bad (VT has an aluminium core). You need to be very careful when fitting accessories to a car and that they are earthed properly, otherwise you end up with stray currant in the radiator which destroys them in no time. Also, with aluminium radiators, it's absolutely crucial that you run quality coolant at the specified ratio.
    VT Acclaim Wagon
    Oct 2008
    Obviously, quality coolant was not used before I got the car, as for accessories, the car has nothing that was not fitted as original equipment by GMH. I think the previous owner managed to damage the radiator and this has cracked the auto trans cooler in the radiator. One of the thermo fan bolt holes is broken in half and the fan housing is hanging in the breeze on that side. Next to fix on my to do list.
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    my Vx has oil in the raidator, but no water in the motor, i think i have the same probabmlem, with a crack in the raidator,
    just wondering what a new raidator is worth roughly? if anyone happens to know off hand
    VT Acclaim Wagon
    Oct 2008
    rednut 80, do you know the difference between the smell of transmissiom fluid and motor oil? If you do it is one way of working out what you have in your radiator. If your trans fluid is not showing signs of burnt clutch, ie brown then the oil in your radiator will have a red orange tint to it. As to what a new radiator is worth. Twin trans cooler models are available on ebay for $130, free delivery in Sydney, $18 in Melbourne or Brisbane. Their warranty is 12 months unconditional or $15 for the same conditions for 2 years. Like buying insurance for your car. Of course, if you have money to burn, you can buy radiators for almost any price. I have seen them at over $500. With a 12 month warranty
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    yeah, mine has definatly split, i have had a mechanic have a look and he told me the motor is fine its just the raidator, i dont really have time to fit it myself as i work from 6 most morning till about 5 each night,
    holden can supply a replacement raidator for around 500 bucks, think ill call red devil or someone similar tomorrow
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by REDNUT 80 View Post
    For the vt's on ebay around $130---160
    But be careful some are made in china
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    yeah thats what im worried about, preferably i want a anrad if its available, but as long as i get good quality im not to fussed,
    99 VT Sedan
    Feb 2010
    Most are made in taiwan
    But some are china
    Just ask befor you buy it....
    But on the other note..I have read here on jc they have had tawian radiators and they blew up like a ballon.........
    I have a tawan in my car since i bought it..Seems ok
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    got the raidator replaced today, and hoses, clamps, cap, thermostat,
    cost me $515, little more then i really wanted to spend, but considering i didnt book in, and they got it all done within a few hours im happy,
    and i got a 2 year warenty
    99 VT Sedan
    Feb 2010
    Wow $515 sounds alot
    Where is this radiator made at???
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    dunno i didn't realy get a chance to check it out, just checked the warenty and its aparently 3 year warenty
  15. #15
    VT Acclaim Wagon
    Oct 2008
    the radiator I mentioned earlier would be $175 with 3 year warranty, Fit it yourself in an hour if you know which end of the spanner is called "box". $340 to do other things with. These days most brands of radiators available in Aus are made in Taiwan and China and are generally ok esp with 3 year warranty.
  1. Radiator VN serie 2 (radiator cap) on a serie 1 (no raidator cap) ?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2009, 12:07 PM
  2. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  3. Radiator fan
    By mezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-11-2005, 04:09 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
