Results 1 to 11 of 11
Thread: My fuel reading in my Vt is stuffed!!
    2010 Holden VE SIDI SV6
    May 2009
    Default My fuel reading in my Vt is stuffed!!
    hey all,
    yesterday i went to put fuel in my holden vt v6 ex. The fuel reading in the cluster said it was close to full. So i wanted to top it up because fuel was cheap, it ended up costing me $68 to fill?..... Wanted to know if i need a new cluster or could be a little thing i could fix to help.
    Cheers All,!
    1998 VT Acclaim S1
    Feb 2008
    Does your needle drop to Empty when you turn your car off?
    Just before you start your car, press and hold Mode and Up buttons, then start the car. Once your car is running, you can let go the buttons and scroll through until you get to "Fuel Remaining" screen. As you're driving, the fuel remaining number will drop. Just keep an eye on it for a few days as you drive around and compare that against your fuel gauge.
    If the "Fuel Remaining" number doesnt drop after a few days long distance drive, your fuel level sensor in the tank is sticking or stuffed.
    If the needle on your fuel gauge doesn't drop but your "Fuel Remaining" number is indicating correctly, its probably just your fuel gauge needle is stuck hard or bad contact at the back of the cluster.
    May 2009
    hey mate just tried it before i got it to the right mode F**** L but mine was staying at 45 going to 56 and staying between that just jumping, and my fuel reading says its way clear past half way? if its my fuel sensor how much do they cost to get done?
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    Quote Originally Posted by ACEMonkey View Post
    that doesnt help mate, they both run off the same sensor
    doin skids for the kids and doughnuts for the grown ups
    '98 vt berlina
    Feb 2010
    Quote Originally Posted by slepar View Post
    yes it does. it'll tell you if the fuel gauge itself is working properly. if you have a stuck needle (mechanically), the sensor might still be working and so is the digital read-out.
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    drive it till its under 1/4 tank, might have to check with a stick lmao, dont drill holes kiddies, and then pul the pump out, i did this at the wrekers frst so i knew how it came out on SOMEONE ELSES car, youl need a seal i think?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VXII
    Nov 2009
    Last I heard, Holden were still looking for suggestions as to how to fix this problem. They're well out of warranty now, and care factor has reduced to zero.
    I saw this on hundreds, if not thousands of Commodores, and at the time there were almost as many campaigns from Holden attempting to rectify this problem.
    The most common problem was that the fuel needle goes to empty before the actual level does, but above half it's fairly accurate. Because most customers had more fuel than they expected, it wasn't thought of as a critical fault.
    VX lumina
    Jul 2008
    SE Melb
    just a quick question?
    how big is the vt/vx fuel tank?
    mine light just came on so i filled up.. ended up putting in 70L i got a feeling it is a dodgy pump.
    '98 vt berlina
    Feb 2010
    vt petrol fuel tank is 75L. i never filled up my petrol tank before since mine is dual fuel. but 70L if the light only just came on doesn't sound right to me too.
    VX lumina
    Jul 2008
    SE Melb
    Quote Originally Posted by tk55 View Post
    jerry can time!! gonna rip them a new one.
  1. Ohm reading of the standard vh fuel sender?
    By rbrtm in forum Electrical Wiring / Questions
    Last Post: 06-04-2010, 02:03 AM
  2. Faulty fuel reading *help
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-01-2008, 11:15 PM
  3. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  4. trip computer erronous fuel reading
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-08-2006, 07:43 AM
  5. Is this fuel consumption reading right?
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2005, 01:11 PM
