Hi People,
Ive been keeping an eye on my DriveBelt in my VT .
Due to get changed very soon
I Noticed that one of the Pulleys was not spinning while the car was running .... How is this possible
and why is it not spinning ?
only thing i can think of is the bearings have seized up caused by worn bearings geting to hot then expanding and when you turn the car off they fused together ands thats one possible way this could have happened. you can get bearings on there own and fix it yourself which makes it heaps cheaper
yeah, someone said in another thread the bearing only cost about 5 bucks!
but you sure it's not spinning? the mount bit is not supposed to turn so it might looks as though the pulley is not spinning.
if it is really not spinning the belt would get really hot. i suggest you not driving it until it's fixed.
edit: replace the belt too after you replaced the bearing. slipping belt is no good for your engine.
Which pulley is it? I think you might be referring to air con pulley which is in fact spinning, the clutch which is in front of the pulley doesn't spin unless the air con is on.
MY RIDE
Its the pulley directly below the distributor cap ?
Found the problem. I looked in the dark.
