Results 1 to 16 of 16
Thread: VT Supercharged overheating problems
    VT Supercharged
    Jun 2010
    Default VT Supercharged overheating problems
    Hey guys, im new to the site. Any information regarding overheating, over pressurising in a supercharged L67 3.8LTR.
    Its a Ported 17psi M90 charger with head work and 20tho over bottom end (all balanced)
    Big Cam haltec computer W2A Tower of terror intercooler ETC. Engine has had around $15G spent on it and i dont wanna cook it completely.
    I have changed water pump, radiator, all hoses, thermostat etc
    When the engine is cold it holds pressure at 125kpa. As soon as u start it and it warms up. The pressure goes through the roof but looses water and over heats.
    Any one have any idea what would cause this?
    car
    Jul 2006
    greensy, melb
    sounds like theres a blockage somewhere
    "A life lived in fear is a life half lived"
    VS l67 statesman
    Dec 2008
    VT Supercharged
    Jun 2010
    I have bled the system. i dont know wat it could be besides a gasket or head.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Where is the coolant going? Is it being pushed out the overflow bottle or is it going somewhere else. It does sound like a headgasket or cracked head. Only other thing i can think of is that your heater tap is not turning on so you cant fill your cooling system fully and have air in the cooling system before you start.
    VT Supercharged
    Jun 2010
    Its because of the heater tapp that all this started. i have just replaced it and it does work. im pretty sure the coolant is going through the exhaust. its got a real sweet smell to it lately...
    Apr 2006
    Mt Gambier SA
    You could check the spark plugs to see if any coolant is getting into your cylinders. There wont be any carbon on them if water is getting in.
    VT Supercharged
    Jun 2010
    yeh we pressure tested the radiator and removed spark plugs 1 at a time while turning the crank over by hand... we didnt loose pressure and had no water in cylinders, we are thinking its intake manifold gasket.
    Apr 2006
    Mt Gambier SA
    Quite possible it is intake manifold gasket as it seems to be a common problem even on standard engines. The extra boost you have will only make matters worse.
    VT Supercharged
    Jun 2010
    VT Supercharged
    Jun 2010
    Replaced the LIM gaskets with metal ones. the plastic ones were screwed. but filled the radiator and bled the system. was running at the right temp untill we took it 4 a drive.
    Overheated again, rebled the system and got heaps of air comin out. topped up the water and drove it again. then it over heated again...
    any ideas?
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Default regarding ur overheating
    Hey there vts have you replaced the radiator as it could have blockages in the cooling fins i have a l67 and when the radiator went it was fine at idle but once you started driving bang its started overheating ,
    if it has blocks it could be fine at idle to keep her kool but once you start driving it will overheat as the water is not circulating enough to keep it kool while at driving ,as to your previous replies you say you have check the radiator pressure it will hold its pressure as its not leaking anywhere but im am guessing it could be that ,dont hold me to that also have you changed thermostat etc .
    good luck with it hope that helps .
    cheers bhopper
    VT Supercharged
    Jun 2010
    I thought it was that to so i got a brand new one in there . so now i got a brand new 1 plus one thats 6mnths old. and yeh the thermostat was the first thing i checked.
    VX S S/C & BA XR6T
    Feb 2009
  15. #15
    VT Supercharged
    Jun 2010
    all the cooling system is brand new. all hoses radiator, cap, heater tapp. etc.
  16. #16
    VT Supercharged
    Jun 2010
    All good now guys. was just the lim gaskets and a leaking intercooler seal. back terrerising the streets of brisbane yet again
  1. vs supercharger overheating problems?
    By mz-v6-2c in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2010, 10:10 AM
  2. Holden VS overheating problems etc.
    By blindworld1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2010, 09:56 PM
  3. Overheating Problems
    By The_HSV_Chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2009, 09:57 PM
  4. Problem with overheating VY Calais (Supercharged V6)
    By Benjamin K in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-11-2008, 07:12 PM
  5. supercharged V6 overheating??
    By lilkel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2008, 01:20 PM
