I have to pull my heads off again for a second time now after blowing the gasket So i was just wondering what else should i do while i have it apart? Its a VT Supercharged 6 just stock standard but plans to be suped up soon i was thinkin...
New alloy LIM gaskets,
porting LIM and Charger ( does anyone know if this is a good idea without a intercooler on at all? )
new seals and gaskets all round
possiably port heads as well
anything else i can do while its apart?
Im also probably pull oil pump off as well to fix slight leak so any sort of mods around that would be good to
cheers
stronger valve spring? higher ratio rockers?
port and polish, bigger tb
Chev badges are an instant fail
