Results 1 to 7 of 7
Thread: Radiator Please help
    99 VT Sedan
    Feb 2010
    Default Radiator Please help
    Hi there
    I got a pressure check done on the weekend
    Trace down 3 tiny water leaks in 2 heater hose's and top radiator hose
    So i fitted them all
    Then i opened up the radiator cap
    Undone the bleed screw
    Started toping in up
    It got to 90 degress but(i have 82 degrees thermosat)
    I am not getting anything out of bleeding screw only air
    I press the top readitor hose only hear air coming out
    Little bit of water but its mostly air
    I looked around no other water leaking
    Can someone please share some light on this??????????
    Please any comments Welcome
    Thanks in advance
    VP Exec
    Jun 2005
    Are you using a funnel, sealed against the radiator filler neck, to lift the water level above the level of the bleed screw?
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Cheap6 View Post
    Thanks for the reply
    Last time i did top it up i use a coke bottle cut in half
    But this time i didn't bother.
    But i will try this tomorrow
    ( when toping up i had heater on...and water was coming to top of radiator)
    Is all this correct way to do this????
    Or a funnel a better way??
    Any other things could cause this??
    Thanks for your help
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Once water starts coming out the top of the radiator, start your engine and let it warm up so the thermostat opens and this should let most of the air out. Then put your cap back on and go for a drive around the block, then try bleeding air out through bleed nipples.
    VT Acclaim Wagon
    Oct 2008
    2 litre coke bottle with the bottom cut off. You have to stop air getting in the filler neck and get the fill level above the top of the thermostat. The illustration in the GM service manual shows the filling tool to be a glorified coke bottle but with an attachment like the outer rim of a radiator cap which is fitted to the radiator filler neck to hold the filling tool firm and water proof. Makes the job easy. So does a coke bottle. If you are doing a complete refill with coolant/inhibitor, put the inhibitor in first then top up with water.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by graham7773 View Post
    Thanks for the tip
    I was only using half 600ml bottle
    But i will now use the 2 litre
    Thanks
    VT Acclaim Wagon
    Oct 2008
    just an addition to my previous post, where the rim on the neck of the coke bottle is, wrap it in a few layers of electric insulation tape for a better seal in the radiator neck
  1. Radiator VN serie 2 (radiator cap) on a serie 1 (no raidator cap) ?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2009, 12:07 PM
  2. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  3. Radiator fan
    By mezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-11-2005, 04:09 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
