Results 1 to 5 of 5
Thread: Highbeams turn on/off by themselves
    None
    Apr 2010
    Default Highbeams turn on/off by themselves
    I've also had this exact problem on a VS i also drive.
    It's worse on the VS (but it's never driven), but in the VT even going over a bump the highbeams will turn on for a split second. Anyone else got this problem? I assume it's a problem with the inicator stalk or something, but it drives me nuts, and im sure it would annoy some drivers as well.
    Any solutions?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Yes it is most likely to be the indicator stalk which needs replacing.
    MY RIDE
    VT Berlina S2
    Nov 2008
    SA
    same answer, it used to happen to me too and that was cured by replacing the stalk with one from the wreckers
    VT Executive
    Apr 2010
    Yep as above indicator stalk, you can check just by turning your headlights on and "wiggling" the stack backwards and forwards, if it turns on/off then there's your answer, my mechanic changed mine for 100 bucks but i think you could by one from ebay or the wreckers and do it yourself for 20 or something?
    VT Berlina S2
    Nov 2008
    SA
    yes $20 is good
  1. help!! vs headlights only working when highbeams are on
    By whitey152 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2009, 10:27 PM
  2. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  3. Cant flash highbeams since L3 luster con
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 10:56 PM
  4. highbeams stuck on
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-02-2006, 09:05 PM
  5. VT ABS and Highbeams
    By vinnywelsh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2005, 01:22 PM
Tags for this Thread
