Results 1 to 4 of 4
Thread: Vt 5.0l Waterpump
    VT 5.0ltr Wagon
    Nov 2009
    Default Vt 5.0l Waterpump
    Hey
    I took my car to the mechanics the other day coz it was using more fuel than usual. they did a service, cleaned the throttle bodies, replaced the spark plugs and cleaned the MAF sensor. They also said that my waterpump is o the way out (got play in it) and said that by replacing the water pump this will fix my fuel problem ( all the other stuff didnt, just made car run alot smoother). I was wondering if that is true.
    P.S replacing waterpump tommorow.
    Thanks
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I can't see how a water pump with some play in the bearings will have any impact on your fuel consumption. Will potentially make it smoother and quieter once replaced. The other items you mentioned (except for the fact that you only have one throttle body) should give you some improvement provided the ignition leads are still OK.
    2002 VX Calais
    Apr 2005
    Gold Coast
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    If it is using more fuel than normal try replacing the fuel filter. It could also be faulty oxygen sensors or temp sensor or the thermostat is stuck open.
  1. Waterpump failure.
    By hako in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2010, 11:38 AM
  2. vs v8 waterpump?help needed
    By hold on boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2009, 05:19 PM
  3. vn v8 waterpump question
    By whatawookie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2009, 09:19 AM
  4. Waterpump Change
    By MR 1JZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 10:44 AM
  5. vp waterpump
    By elba in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2008, 10:49 PM
