Results 1 to 11 of 11
Thread: VT Auto no Drive once warm
    VH SS
    Dec 2006
    Default VT Auto no Drive once warm
    Hi all. I have tried to find someone with the same problem on here and I don't know much about autos so bare with me. My wife was driving the car during the week. Stopped at the lights and waited a good 3 min before trying to take off again. She tells me the car just started to rev. She had to keep the car at about 5500 rpm for it to crawl off the road. She parked it there until I could get there after work. As it was dark by this stage I just jumped in and started to drive home. As i was driving home I could feel the rpms rise but i was going slower. I pulled over checked the fluid level. To dark so I walked to the local servo bought some oil, returned to car, chucked in the 1 litre and drove home. I had assumed the car was low on fluid but have checked it today and if anything its might be too high. (after I added a litre last night) I have allowed the car to warm up and again loose drive and reverse after 5 min. Car cools down and its back again. All gears change fine and its very smooth when cool.
    Any ideas
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It might just need a fluid and filter change. If it hasn't been changed in a long time the fluid could have deteriorated. Adding a bit of new fluid might have help a bit but not enough.
    MY RIDE
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Hmm, lost drive and reverse, I read about that being a common problem. I'd take it to an auto transmission place and they should be able to tell whats wrong. To me I'd say the gearbox is damaged, the bands could be stuffed. I know the first gears I lost were drive and reverse in one of my cars ages ago.
    Has the gearbox heated up heaps?
    What colour is the fluid (probably won't be able to tell as you put some new fluid in)
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Was at the misus old mans work shop the other day, he had the same problem with a ford telsta or wat eva they r. drove fine cold but as soon as it warmed up lost all gearing. turns out the box is stuffed so id assume the same thing here??
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    not sure but do you have the oil cooler built into the raidator? perhaps check your coolant for oil, i imagine if the radiator can suck the oil into it it could also push water into the box, and make it boil a lot faster?
    VY Ex-cop
    Mar 2006
    maybe a cracked clutch housing inside tranny, cant remember exact name but it houses the clutches and attached to inputshaft is of bell shape design. these have tendancy to break/crack on V8's and give those symptoms. if it is, very costly to fix. it would have burnt the clutches as well.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Sound like a job for a trans specialist. If it has got enough trans fluid and is slipping then you either have a faulty pump in the trans or a pretty bad internal leak. The trans fluid is thicker when cold so it will drive then but as it warms up and thins out it will bypass easier.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    When was the last time the transmission was serviced? If it has been a while it is a good bet that the fluid is on its last legs. Make sure the fluid is it at the correct level. Get it serviced and hope for the best. It does sound like you will be up for a replacement transmission though.
    VH SS
    Dec 2006
    Yep, Autos knackered.
    I'm looking for a changeover. Does a supercharged vt use the same box as the normal?
    VXII
    Nov 2009
    Quote Originally Posted by sleepa View Post
    So, which gears did you lose next?
    Mar 2004
    Quote Originally Posted by Logz10 View Post
    No they are different.
    Check ebay, someone had brand new ones for $1800
    Search for "COMMODORE VT VX V6 SUPERCHARGED AUTOMATIC TRANS NEW"
  1. Best way to drive a vs (Auto)
    By adamrollo9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2009, 05:14 PM
  2. vr auto lost 3 and drive
    By Robs vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2009, 11:42 AM
  3. vs auto no drive
    By alloywelder in forum Electrical Wiring / Questions
    Last Post: 12-01-2009, 11:03 PM
  4. VN auto has no drive
    By newtownbob in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2008, 03:25 PM
