Results 1 to 3 of 3
Thread: spark Plug leads
    VX Executive
    Nov 2008
    Bolton point Newcastle
    Lightbulb spark Plug leads
    dose anybody know how long of all the plug leads on a VX V6 .I brought a set about 4 months ago but are to long and I broke off 3 of the ends when taking of the plugs. I want to fix the set for a spare
    lukevincent's Avatar
    lukevincent is offline VT Super6 all the way.
    98 Supercharged VT 'Spac' Commodore
    Jun 2010
    BUNBURY
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    cant remember off the top of my head the correct lengths but i can tell you how to fix the ones you got. all you do is remove the spark plug boot completely,once you have done that you will see a metal sleeve around the ht lead. there will be a split in the metel sleeve,with a small flathead screwdriver prie the metal sleeve apart gently by insertng it in the split on the metal sleeve. it wont take much effort before it becomes loose & you can remove it from the ht lead. once the sleeves off cut the ht lead to length. to get correct length for each lead use the old leads as a template.
    if you need anymore info just et us know
  1. Which Spark Plug Leads For VT V6
    By Swift Jimmy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2006, 08:10 AM
  2. spark plug leads
    By AndyVKSSA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 11:26 AM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. Spark Plug Leads
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2005, 01:49 AM
  5. spark plug leads
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2004, 01:30 AM
