Im currently doing a V6 conversion and had a real noob questions im sure someone on here will be able to help me with.
On the VT's theres three lines that run through the firewall. Two being suppy and return to the fuel rail and another hose that connects to a sensor on the back of the manifold. Where does this go to? vacuum?
Any help will be most apprciated.
cheers
third line goes to the charcoal canister, which is mounted just forward of the tank.
the 'sensor' you mention is a vacuum valve that opens under certain conditions as decided by the computer. vacuum is on one size, and when it opens, it sucks fuel vapour out of the charcoal canister.
Thanks mate!
can you keep me informed how this goes, be it pm or what ever. I have a swb paj that i want to convert just need the inspiration to do it like you! mine has a 5.5" lift and 33'' muddies and is a real off roader just needs a little more poke!
.:Blown VT V6, DAJ37:.
