Results 1 to 12 of 12
Thread: Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    Exclamation Vx ss ls1-abs & traction control lights stay on & traction control switch not work-
    Hey all. Have looked & searched through this entire site but cant really find anything that says,this is the problem & this is what you do. Heaps of people have simiar problems by the look of it so has anyone found a solution to the following problem yet??
    Got a VX S2 SS LS1 MAN,starts & stops fine,no brake lock up etc that i have noticed. Problem is when i start the car the ABS & Traction control light stays on,the traction control switch doesnt seem to work as pushing it doesnt turn on or off the traction control light. So what the problem?? I have read people saying change the ABS unit but i have also read people saying ok,i have changed my ABS unit but the same problem happens. So this cant be the problem,there must be another cause or issue. Has anyone found it or know how to fix the problem??
    Yes,have checked & replaced all fuses,yes have removed all plugs concerned & cleaned but still no joy. HELP!!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I have a similar problem in our VT Senator, the 'trac off' light comes on after driving for a while and the button has no effect. I have put it down to a faulty wheel sensor, I just haven't had time to look at it yet.
    Visit my Facebook page
    VX Berlina Wagon V8 A4
    Dec 2008
    Feb 2010
    IPSWICH
    Yes,thats what i thought it coud be as well but just checked those before. I,sat in the car for a bit scratching my head then decided to remove the fusebox under the dash for a look. It was a bit dusty/dirty behind there so i gave it a clean,once i did that i noticed a couple of wires had burn marks on them. I looked further & there was a live wire loose which was causing the burn marks,found where it was supposed to go then put it back in. Re-taped with insulation tape a couple of things then put it back together again. Turned the key on,started the car up,bingo-no abs light came on & traction control switch is working again. Wether this was a complete fluke,i will never know but alls good again with the VX. Will keep an eye on it & see if the fault comes back but,at this stage fault is gone. I dont know if this is the same problem for anyone else but,check it out,you never know
    Feb 2010
    IPSWICH
    Quote Originally Posted by WAGONBEAST57 View Post
    Yeah sounds like the ABS Module mate
    Problem with that one is that so far what i found was those who thought that may be the case & replaced the ABS module still had the same problem afterwards. So there maybe some manufacturing fault,who knows but have fixed my problem now & it wasnt the ABS module...this time
    Dec 2008
    Another thing that happens to mine, when the stupid holden dealerships decide to "clean" the engine down, without telling me, when I get the car back the TC light stays on and the engine warning light. Goes off after a while and never comes back on. You could have some moisture or something somewhere it doesnt belong???
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    vy ss5.7 auto
    Dec 2009
    i had the same problem with my vy ss .i put LED tail light bulbs in a few months later the cruise and tractin control would work sometimes and other times it wouldnt found after a friend of mine took his car to holden with the same problem that the LEDs stuff with the voltage to the break light switch witch intern affects the cruise and traction control so i took them out so i took them out and problem is gone
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    Thats right dude, LED Taillights don't get along with the cruise control,, not so sure about the traction however?..
    Something about the cruise that uses an earth that is on the same line as the taillights.. So with LED they use less amperage to run which floods the cruise unit.. Theirfore switching itself off
    Easy way to get around it is to wack in a few "Load resistors" in parallel with the taillights, not with the brake lights like i did :P..
    Ya can find the load resistors on ebay for a few bucks. They work pretty good.. Sorry about drifting off-topic :P
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by VTLS1 View Post
    Can you please tell me which wire this was??? colour location???
    I have changed abs module and still having abs and trac light coming on
    VX Spac
    Jun 2009
    Smile
    don't know if problem solved already but if not, try to check if all your brake lights are working. i have this same problem 4 years ago when the trac control light suddenly turns on and it seems like the trac control switch doesn't work at all. what i did is i check all the fuses and light bulbs of my car and i found out that one of my break light is busted. i replaced it and everything's normal again. trac control works again.
    vt ss 5.7 ls1
    Jun 2009
    Auckland New Zealand
    exactly the same with me with the tail light bubs it must read as a circuit fault and as soon as you replace the faulty bulbs , fixed, try that
  1. ABS, Engine, Traction Control and Airbag Lights
    By nolim8ts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2011, 08:52 AM
  2. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  3. LEDs in traction control button and rear power window switch
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2008, 05:05 PM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. traction control switch installation
    By jarrod587 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2007, 07:26 PM
