Results 1 to 19 of 19
Thread: changing engine mounts on a VT V6 berlina??
    Non! Sold the Berlina
    Apr 2010
    Eastside, Adelaide, South Australia
    Question changing engine mounts on a VT V6 berlina??
    Hey everyone !
    I have a 1998 Holden Berlina V6 VT and the engine mounts on it have gone. The car has done around 173,000ks and when i had it up off the ground i saw that it had a few problems The sump is currently resting on the crossmember and im pritty sure its making the ride a lot bumpier and rougher.
    The question I want to know is how hard is it to do a DIY with changing the engine mounts and is around $50 each mount sound right ??
    Any advice would be apreciated
    Danny
    Need a V8 or Turbo...!
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I paid $400 for mine i think, dropped the car 7am grabbed it 4pm. What is involved i'm not 100%, but i know A/C can be removed for easier access.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Got to lift the engine off obviously, not easily done in backyard by one person.
    Ronald Reagan (1986)
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Undo the bolts to cross member, slip in a suitable piece of 6mm steel plate, (this steel plate will lift the motor off the cross member) then tighten mount bolts. Simple and CHEAP!
    Did mine about 50K ago, still no problems.
    VT SS LS1
    Oct 2008
    gold coast
    hit up ebay for mounts.
    holden wanted to charge me $160ea
    brains auto got me 1 for $80
    i got the second one from ebay for $40 lol
    ive got the second one sitting on my bench so if someone writes up a how to id like to see it as well.lol
    aparently passenger side is alot harder than drive side.
    car
    Jul 2006
    greensy, melb
    the reason holden charge so much is they are meant to be an oiled filled mount which makes them alot smoother and better than the rubber ones
    "A life lived in fear is a life half lived"
    Apr 2010
    Thanks guys for the advice!
    Ive got a block and tackle at home im just not sure if ill bother with all the work!!
    Danny
    Apr 2010
    Apr 2010
    cheers mate ! do u think you could write up a detailed how to do or help find one out there?
    thanks again pablo
    danny
    stevieVT's Avatar
    stevieVT is offline The apprentice
    1998 VT berlina
    Mar 2009
    central coast, nsw
    Quote Originally Posted by pablo View Post
    WTF this doesnt solve your problem. When your engine mounts go they sit on a pin that runs though the centre of the mount. this is what helps cause the vibration. why would you even bother sliding a peice of metal in the gap it still lets the engine connect to the cross member and create a vibration. and your mounts are still stuffed. :/
    And Tbh i cant stand doing them on a hoist at work so i wouldnt bother trying for a diy job
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    ya dont need a block n tackle, just use a jack and put a little bit of timber accross the sump and lift it 10mm or so to take the pressure off. drivers sides pretty easy, but other sides a pain, have to unbolt the aircon from the block and push it aside. (with out letting it hang on the aircon hoses) n do 1 side at a time
    and $50's about right too
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    like previously mentioned rhs is straightforward. lhs a/c compressor needs to unbolted and shifted forward and the engine mount bracket needs to be removed from the engine to remove the mount. lining this bracket and mount up is easier done by loosely bolting the bracket to the engine first then manouvering the engnie to locate the mount into the crossmember. leave the lhs loosely bolted up to make the rhs easier to bolt up.
    if you dont have a jack and an assortment of spanners and sockets then leave it to a mechanic.
    May 2006
    Hey stevievs, didn't you read my post properly, I said that what i did worked for me, AND still is. The pins weren't touching and still arn't, only the sump was touching the cross member and that was MY problem!.....and now that I shimmed the mounts, the problem has gone......simple.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    I Paid 280 to have the ones done on the VR.
    Paid $70 for the mounts and $210 labour to fit. Bargain i think, and VRs are much harder, took them all day.
    What about the Trans mount? is that much effort to replace?
  15. #15
    Apr 2010
    Thanks guys for the advice! Ill ask a couple of mechanics and see if my brother has any idea or changed them before
    once again cheers
    danny
  16. #16
    99 VT Commodore
    Mar 2010
    south east queensland
    im literally in the process of replacing the mounts on my VT Exectutive.....so far i have the passenger side mount bolted to the bracket which is loosely bolted to the block and the mount is through the holes with nuts on loose..the drivers side is becoming a pain!!!! i cant seem to get the engine high enough to slide the mount in and into the holes???
    any tips on gettin the mounts to line up? drivers side...?
  17. #17
    Mar 2004
    I think the drivers side, you place the mount in the kframe and spin the nuts on enough to hold it, then lower the engine down until the holes in the engine block line up with the mount and put the bolts in.
    Do a search for "VT engine mounts", you will find its all been covered in detail before.
  18. #18
    johnny_boi85's Avatar
    johnny_boi85 is offline johnny_boi
    VT Executive S1 3.8L 98 and VE Omega S1 3.6L 07
    Oct 2008
    Nowra N.S.W.
    i just replaced both mounts in my vt what you need is a rattle gun to make things easyer a jack socket set and spanner set (1) put the front of the car up on ramps or car stands (2) undo the bottom two bolts of both mounts then put a peice of wood on ajack and jack up the sump as far as you can if you remove the engine cover from the top of the motor first you can lift it higher (3) remove the fan belt and air con compressor from the passenger side (4) i started on the passenger side but its up to u undo the three bolts that hold the mount bracket to the block once you have to mount out replace the mount to the bracket and put back onto the car (5) drivers side i had a bit of trouble with this side you have to undo the few bolts that hold the mount bracket onto the block i found it hard cause i could only turn the bolts a little at a time so it took forever once out again replace the new mount to the bracket and place back onto the car (6) ok now you have the new mounts in place when you lower the engine down i lined the drivers side up and got the mount studs in a little and put the bottom nuts on a few turns just so they didnt pop back out (7) now what i did was with a jimmybar or some kinda poll i had to hit the studs over to make them go in the holes if you get them to line up do up the blots place the air con compressor back in place dont forget you fan belt and that should be it give your self a few hour to do it and it is easyer to do with a mate hope this helps
  19. #19
    Oct 2008
    Nowra N.S.W.
    SV6Z i just wrote a step by step quide to maybe help any one if you have any probs with the studs not lining up i got the drivers side to sit in just a bit first and put the bottom 2 nuts on a few turns to make sure they didnt come out again then i got bar a tapped the passenger stud over till they popped in i got a mate to work the jack raising and lowering the motor as i needed dont be scared to give the studs a good had hit over but at the same time try not to damage the tread on the studs hope it helps let me no how you go CV6Z and DannyVT
  1. diagram of rear bumper mounts - vt 1997 berlina
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2008, 08:47 PM
  2. Changing VP engine mounts
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2008, 08:56 PM
  3. Changing VN engine mounts
    By aokman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2006, 02:01 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Changing Engine mounts help needed..
    By TI0350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 07:21 PM
