I have an early VT 3.8 V6 motor I am doing the heads on. I have access to a pair of low Ks VX heads. Any dramas to change from VT to VX heads? I ask because the valve regrind gasket set set changes from VH750000 or thereabouts. Mine is VH733000ish so early. Anybody know what the difference is?
Doesn't matter, Rang GMH and they told me the heads are same part number so interchangeable. Now I need to find out why the valve regrind sets have a different part number......Rang GMH again. OK, now I know what the difference is. The VX and VT heads are the same, the difference is in the manifolds so VX heads will fit my VT motor and I have to use the VT gasket set and manifolds. Comments? Opinions?
yeah far as i know heads are the same so dont see why you cant fit them to your vt. the manifold is differnt on a vx well shouldnt say totaly differnt just wont bolt up on a vt motor but the desinge is pretty much the same.
