Results 1 to 11 of 11
Thread: Help Needed - Ecotec Coolant
    Wagon
    Feb 2010
    Default Help Needed - Ecotec Coolant
    Hey all,
    Now before you tell me, yes I have searched all over the internet, but haven't found anything helpful unfortunately.
    My coolant needs replacing in my 97' 3.8L Ecotec VT wagon, but I'm a little unsure of what coolant I need, how to flush the radiator and what sort of chemical flush.
    I want to know what coolant everyone uses in their Ecotecs, how they flush their cooling system and what brand of chemical flush they use.
    Any help will be greatly appreciated!
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by WyldOne View Post
    Hey all,
    I also need advice on this?
    What i do to flush coolent undo your bottom radiator hose....Run the hose into the top of your radiator until water turns clear...
    And i use 50/50 mix...
    This is just what i do don't know if it correct??
    VX lumina
    Jul 2008
    SE Melb
    i wouldnt use a rad. flush,
    drop the bottom rad. hose, and let all the water out... put your hose into the top of the radiator and put your heater on full (full speed and full heat) keep letting the water flow untill the water is clear...
    replace hose.
    i use coolant concentrate (the green stuff), pretty much any brand will do... use one that says "makes up to 10L", pour it into the radiator (all of it) and fill up with water...
    let it run for a while (leave heater on) (thermostat will open up), and when the water drops keep topping it up. when it wont take anymore... pull the throttle cable and the coolant will drop by 50-100ml, quickly fill it up while holding the throttle and replace the cap.
    then pour about 1L of water into the overflow.
    hope that helps
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by aazn View Post
    replace hose.
    hope that helps
    That explains it very well this is exzatly what i do
    VX lumina
    Jul 2008
    SE Melb
    just reread what i wrote and i used the word "hose" too many times.... you should be able to work it out.. hose and tap hose..
    and i forgot to mention "remove the radiator cap" ahh you should be able to work it out.
    Dec 2009
    you need a 50/50 mix and I think the cooling system has a 12 litre capacity so you need 6 litres of concentrate and you need to bleed the air out of the system while filling it there is no need to start the motor if you bleed it properly.
    The hardest part is getting 6 litres or more out of the system before you add the concentrate.
    VX lumina
    Jul 2008
    SE Melb
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    If you don't remove the 'knock sensors', one in each bank, less than half the 12 liters of coolant will drain when only the bottom radiator hose is removed!
    VS COMMY
    Mar 2009
    I take the radiator to a radiator shop and get them to flush it out as they pull the thing apart and they run a rod thru all the banks making sure they are unblocked and clean and solder the radiator back together.
    Coolant make sure they are for a alloy head.Remember what you pay is what you get.
    Dec 2009
    Quote Originally Posted by ss350chev View Post
    The VT V6 radiators are aluminium with plastic tanks so can't be soldered, if there that blocked ther einexpensive to replace with a new one. Engine is also cast iron not alloy. Best coolant is Nulon Long life Green.
    VT Acclaim Wagon
    Oct 2008
    This is as brief as I can make the description from the VT service manual
    GET 3 RADIATOR PELLETS FROM HOLDEN
    GET 7 LITRES OF NULON LONG LIFE COOLANT/CORROSION INHIBITOR
    PUT CAR ON RAMPS
    REMOVE THERMOSTAT AND REPLACE HOUSING
    REMOVE KNOCK SENSORS FROM EACH SIDE OF BLOCK
    REMOVE RADIATOR LOWER HOSE AT ENGINE FRONT COVER CONNECTION (WATER PUMP)
    REMOVE TOP RADIATOR HOSE AT RADIATOR
    PUT WATER HOSE IN TOP RADIATOR HOSE AND FLUSH UNTIL WATER COMING FROM BOTTOM CONNECTION (WATER PUMP) IS CLEAR
    PLACE WATER HOSE IN BOTTOM RADIATOR HOSE AND FLUSH UNTIL WATER COMING FROM UPPER HOSE IS CLEAR
    PLACE WATER HOSE IN LOWER RADIATOR HOSE CONNECTION AND FLUSH UNTIL WATER COMING FROM TOP CONNECTION IS CLEAR
    REMOVE COOLANT RECOVERY RESERVOIR AND RINSE CLEAN
    REINSTALL ALL HOSES AND THERMOSTAT AND PLACE THREE COOLANT PELLETS IN TOP HOSE
    PUT SOME SEALANT ON THE 2 KNOCK SENSOR THREADS, REFIT
    ONCE IT IS ALL BACK TOGETHER, PUT 6 LITRES OF COOLANT IN RADIATOR
    NULON LONG LIFE? THEN ADD WATER UNTIL FILLED. BLEED SYSTEM. ADD 1 LITRE 50/50 COOLANT MIX TO OVERFLOW BOTTLE
  1. Help needed after my first coolant flushing...
    By yohn222 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2009, 10:10 PM
  2. Vs Ecotec Disappearing Coolant
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2008, 09:12 PM
  3. what software is needed for tuning vs v6 ecotec..
    By shwarno in forum V6 Development And Modification
    Last Post: 20-05-2008, 01:48 PM
  4. Vs Ecotec Coolant Flush Probs
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2006, 07:20 PM
  5. correct coolant ecotec v6 vs wagon
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 10:42 PM
