Results 1 to 3 of 3
Thread: VT power steering leak - at the rack??? urgent!!!
    99 VT Commodore
    Mar 2010
    south east queensland
    Unhappy VT power steering leak - at the rack??? urgent!!!
    hi all, i have a power steering leak which seems to be comming from the top of the power steering rack??? ive checked all the hoses all of which are tight, and followed the leak up to the top of the rack where the steering rod goes down into it....is it a seal thats busted? if so can i replace it or how do i rectify the problem?
    anybody else come across this problem before?
    cheers
    vn sI 3800 stocker
    Oct 2009
    Default Did you find out the cause?!?
    Hi mate, i am having the exact same leak from the exact same spot, a lot of fluid leaking from the top of the rack where the steering shaft enters the rack body. Very loose orange seal on top. Makes no sense as to why the seal is so loose... Please let me know asap if you found out what the problem was.
    Cheers, Dan
    1997 VT Commodore Executive V6
    Oct 2011
    whyalla,SA
    mines the same, i reckon the orange seal is just a dust seal not the actual pressure seal, was gonna go to a bearing and seal specialist and see if u can get a kit for the rak and pinion, otherwise might have to remove the whole unit, strip the topseal out if possible and get it matched, rather a $10 seal than a whole new unit.
  1. VN power steering rack
    By piantz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: Today, 11:19 AM
  2. Vn steering rack leak
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2010, 02:19 PM
  3. steering rack leak
    By kiwi pup in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2010, 06:16 PM
  4. VP power steering rack leak
    By mickVPace in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2009, 09:25 PM
  5. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
