Results 1 to 8 of 8
Thread: open vx key remote
    kazalex's Avatar
    kazalex is offline karen
    red vx series 2 commodore
    Oct 2008
    adelaide
    Default open vx key remote
    hi, i need instructions to open my vx remote so i can transfer the inside to another shell,if anyone knows how to do it?thanks
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The only way to open them is to cut them open, they are glued together. It is difficult to o a neat job of it.
    MY RIDE
    vt berlina series 1
    Sep 2008
    just go to mr minute and get a new key, its about $80.00 and they give you easy to do instructions on tuning the key to the car, takes about 1 minute
    Non! Sold the Berlina
    Apr 2010
    Eastside, Adelaide, South Australia
    you will break the case but you have to unscrew the two screws holding the key end part and put a 50c coin in the little slot! the twist it to eventualy break the case open.
    hope this helps
    Danny
    Need a V8 or Turbo...!
    kazalex's Avatar
    Oct 2008
    adelaide
    VX Calais
    May 2005
    NZ
    i've just opened my key up recently too, to replace the battery on the cheap..
    i used a stanley knife (craft knife?, snap off blade?not sure what you'd call them in Aus) to cut around the sides where it joins, and slipped a small flat screwdriver in to carefull prise it open.
    and fyi... holden went the extra mile, for those of us cheap and industrious enough to break into the key housing to change the battery... they've also soldered or glued the battery to the terminals!
    well played, holden 1, beaker 0
    VX Executive
    Feb 2008
    With a pair of craft needle nose pliers, you can (carefully!) pry off the spot welded battery terminals and slip in a new battery. Will work but your key will look very ghetto from being pried apart. Its a cheap fix but still can do
    VXII
    Nov 2009
    Quote Originally Posted by beaker View Post
    If you go to tandy or dick smith electronics, you can buy the battery with terminals soldered onto it already for about $2. If you are handy and patient with a soldering iron, all you need to do is unsolder the battery lugs, and resolder the new battery wires to the circuit board.
    Also, I heat a razor blade above a flame and cut through the plastic case. It leaves virtually no mark on the exterior and can be reglued with a couple of drops of superglue. Not too much though or it will be difficult to break apart next time.
  1. Remote engine start on VXII berlina with factory key remote
    By cougar1985 in forum Electrical Wiring / Questions
    Last Post: 02-11-2010, 01:32 PM
  2. can't open VX!!
    By P007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2010, 06:34 AM
  3. Open ECU.
    By soop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-12-2008, 07:16 PM
  4. Can i open my boot , not using my remote.
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2006, 10:03 AM
  5. How To Open Door
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:28 PM
