Results 1 to 5 of 5
Thread: Rubbing noise - front right wheel
    VT Berlina
    Oct 2007
    Default Rubbing noise - front right wheel
    I had my VT services earlier this year and part of the service included replacing the front brake pads replaced. After this I have noticed a rubbing noise in the front right wheel as I drive.
    At first I thought that perhaps the rotor was warped or the machining of the rotor wasn't done well. The noise has never got any worse, but I have been thinking that it could be a dodgy wheel bearing.
    Any thoughts guys?
    VY Ex-cop
    Mar 2006
    without seeing it and hearing it, who knows, could be anything, all we are doing is guessing. take wheel off and see if anything is rubbing around the area.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    increase with braking?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    wheel bearing is a grinding noise and gets louder with increase of speed and gets worse over time! if you get something replaced/fixed at a mechanics shop and then it makes weird noises take it straight back asap.. if you take your time then your decreasing your chances of being able to blame it on them.. where as if your take it straight away they cant say anything gotta love working at a dealership and seeing behind the scenes =P
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Paully View Post
    Any thoughts guys?
    Yeh take it back to the machaic....
    They can do some dogy work!!
    Once I took my car into machaic....With 4 lock nuts fitted...
    When i got it back only had 3 lock nuts fitted....And a differant nut only finger tight!!!!
    As this is all that i could see...
    So from than all the work on my car i do or if i can't do it i will get a mobile machaic..
    I always watch what they are doing!!!
  1. FRONT WHEEL Brake NOISE - me and my mechanic cant find source of noise. help???????
    By northqueenslandvs97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2010, 08:36 PM
  2. noise from front left wheel
    By vpcommo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2009, 07:22 PM
  3. vt ss front wheel bearing noise
    By rox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 03:07 PM
  4. front wheel noise.
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2006, 04:30 PM
  5. Front wheel grinding noise
    By clintonhadenham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-08-2005, 06:21 PM
