Drivers door mirror housing on VT
M
mikemutlow
Guest
Does anyone know how the mirror housing on the drivers door is attached? Mine is currently fitted but it 'rattles' if you grab it; I think the garage did something to it when I asked them to sort out the electric adjustment of the mirror actuators which would not swing the mirror out far enough for me to see my 'blind spot'. Can I easily tighten the housing or is it likely that something has broken - which will mean another 'discussion' with the garage.
VTWGN97
46
vt executive wagon
Open the door and gently pull the a/c vent off and then check for screws holding the plastic cover, take it off and i think if i remember correctly it has a bolt holding the mirror on check if it is tight, if it is i would say they have broke somthing. Just going by memory here so be gentle with it and always look for hidden screws.:unsure:
