Results 1 to 13 of 13
Thread: VT starting probs....
    98 vt s pac
    Feb 2009
    Corowa NSW
    Default VT starting probs....
    Hi guys sorry for the new thread i did a search but no one seems to post what the problem was once its fixed?? Anyway ive been having probs with the VT when starting, when you turn the key it will go chug chug chug chug chug chug then fire up. I have swaped the relays around and it doesn't seem to make any difference checked the leads etc........ any ideas?
    vt ss commodore
    Apr 2010
    by chug do you mean the starter motor is struggleing or is it running a bit rough then after a couple seconds it idles normally
    98 vt s pac
    Feb 2009
    Corowa NSW
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    sound like what i just had problems with on the weekend, if i've read ya post right.
    my car would turn over for 3-5 sec's befor starting. like there was no fuel or it was flooded a bit,........... dose that sound like yours???
    if so- i found out my injectors were leaking, so it was either partially flooded or low on fuel pressure.
    if i turned it off and started it straight away it was fine, just if it had been sitting for a little bit it would take a while to start.
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    vg ute
    Jun 2010
    shepparton
    mine last night stalled and wonldnt start up with out pushing the acculator pedal down abit to get it to idle turns out the fule pump is starting to go that can be worth looking into as they well somtimes play up when they on there way out or it just wont work at all
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by wana s' charge stock vt View Post
    yep sounds similar
    Sep 2009
    goldcoast
    ya may just have low fuel pressure. mayb.
    could try changing ya fuel filter if its been a while .
    get fuel pressure tested
    pull vac hose off the fuel reg and see if its leaking out the port of the fuel reg. (not sure if it has to be running or ignition just swithed on so pump comes on and build pressure)
    or if its easy enough on an ecotec, take off the fuel rail with injectors still attached and fuel lines, sit it upside down so injectors are pointing up, turn ignition on so pump comes on and fills the rails(switch ignition off and on a couple of times to make sure its chockers. DONT START IT) and see if the tips of the injectors fill up/or if any fuel leak's out..
    thats how i found out mine were leaking anyways. swapped injectors and starts instantly again
    98 vt s pac
    Feb 2009
    Corowa NSW
    yeah been a while since the filter was done i'd reckon about 60 - 80,000 k's
    Sep 2009
    goldcoast
    Quote Originally Posted by mynameisearl View Post
    id be changing it. , prob due for a newy so no real loss if ya replace it and its not the problem, only $25 from superheap
    how old are ya plugs??
    98 vt s pac
    Feb 2009
    Corowa NSW
    plugs haven't been done since ive had it and thats about 5 years
    Sep 2009
    goldcoast
    lol, might be a good idea to get it in for a service
    98 vt s pac
    Feb 2009
    Corowa NSW
    yeah its always been on the to do list
    VE MY09.5 SV6 5sp Auto
    Dec 2009
    yer my car wouldnt start, not only that but it would stall every time i turned right. It had a shit load of problems. Paid hundreds for a major service including the plugs being changed and what not and getting a crank angle sensor...and then iv had RACV come out when it wouldnt start. they said it was the alternator......I got an auto elec out and it turns out the whole time it was the battery. the god damn battery. even though the battery indicator was green, it was faulty....for the love of money, check you battery.
  1. starting probs help please
    By maginoodle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-07-2009, 12:04 AM
  2. vt starting probs
    By vpssguy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2007, 04:47 PM
  3. Starting Probs
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 02:16 PM
  4. Starting probs....
    By sharpeidog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 01:50 PM
  5. vk starting probs
    By nezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-06-2004, 10:07 PM
