Results 1 to 5 of 5
Thread: 1997 Vt Noise From Rear
    Scottie666's Avatar
    Scottie666 is offline Scottie
    Vt Acclaim, 1988 Vl Comm,2007 VE BERLINA
    Apr 2009
    Post 1997 Vt Noise From Rear
    Hey guys,
    i am having yet another problem with my VT, it is definitely coming from the rear end, only when i turn a right hand corner am i getting a weird sort of like grinding noise, if anyone can help it would be great, and it only does it when i am turning at about 20klm an hour or more.
    cheers
    Scottie
    vt s s1
    Mar 2009
    Scottie666's Avatar
    Apr 2009
    Quote Originally Posted by vt s View Post
    sounds most likely to be wheel bearing is it louder the faster you go?
    hey mate, no it doesn't get louder as i go faster, it's weird hey i can't pick it, i thought it was my drivers side rear brake, cause the bolts are all tight but it seems loose, but the other side doesn't move, unsure, i jacked the car up off the ground and ran the car and no noises, plus i had that bearing replaced about 8 months ago,
    Scottie666's Avatar
    Apr 2009
    any help would be great, it's making like a grinding noise, and it does get louder as i gain speed, anything over 40 klms an hour, thinking on checking my diff oil cause it sounds like metal on metal and also hear it when i hit a bump?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check your hand brake shoes.
    Visit my Facebook page
  1. vy ute rear end noise
    By randallbass in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-03-2010, 06:56 PM
  2. Rear End noise
    By cjcrow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2008, 04:40 PM
  3. diagram of rear bumper mounts - vt 1997 berlina
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2008, 08:47 PM
  4. Rear End Noise...
    By jwoods997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2005, 10:26 PM
