Results 1 to 13 of 13
Thread: 4wd Tyres on my vt?
    Dec 2007
    Default 4wd Tyres on my vt?
    has anyone attempted to fit 4wd tyres and fit lifted springs to a vt? looking to lift mine rather then lower it just for something different as vts arent worth much these days so going to have some fun with it.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by hump View Post
    Interesting !!
    would be awsome to take it to the bush...
    Sladdo is offline Resident Ford mechanic
    HBD VT V6 5sp Exec.
    Jan 2009
    Murwillumbah
    Why waste your money & de-value your car more so? Swap your VT for a Toyota Corolla 4WD wagon.
    Big_Simmo's Avatar
    Big_Simmo is offline Great White Cranberry
    WM 6L Stateman
    Apr 2010
    Give it a go
    I have only seen it done on a few kingswood's here in perth, not on any commodores yet
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Big_Simmo View Post
    Give it a go
    In sydney once i remeber seeing a vh lifted and 4wd tyres...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You can get Heavy Duty/Raised Springs, put V8 ones of them in the front as they are firmer again, will raise it a noticeable amount, but not enough for serious 4wding.
    You can get some very mild 4wd tyres to fit, but nothing aggressive, personelly I would just got for a knobbley Road tyre.
    I have the above on my ute and it will take mild 4wd tracks no worries, but dont kid yourself, I have been winched and tower out on so many occasions its not funny, never 4wd alone especially in a commy
    Also, Sump gaurd is the best investement as Commy sumps are so low, if its an auto, well good luck with the trans sump.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    MY04 VZ SS A4
    Feb 2007
    North Shore, Auckland, NZ
    Here are 4WD tyres on a VT ...
    If computers have no doors or fences, who needs Windows and Gates?
    Dec 2007
    After some research can't get springs any higher then 25mm for the front but v8 spring are probably a good idea. Not planning on doing any serious 4wding just maybe some beach work and would be going with a mate who has a patrol. But mainly just want something different to every other lowered commodore out there. Is a 235-75-r15 doable only concern is that it may rub on the spring purch on the shock
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I can't see it being roadworthy since most states have the rule regulating acceptable tyre sizes. Most 4WD tyres would have to big of a side-wall to be compliant.
    Ronald Reagan (1986)
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by V8Silverfox View Post
    Lol totaly Awsome
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    I want one lol
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Rusty-Tim is offline Rusty-Tim
    VN Ute, VN wag, VR sed, VN sed, HX Tonner, HA Viva
    Dec 2009
    Chch NZ
    Not sure how similar VT's are to earlier commodores but I am running 235 85 R16 on the back of a VN Ute with shocks designed for lifted safaris and have just boxed up rear diff arms to lift spring mounts. VTs are IRS rear thou arent they so maybe a bit different. Only needed to do a little bit of clearancing of guards to run. The biggest tyres you can fit on VN - VS front ends are 27, 7.5 R14 muds or equilivant. Will probably need to run 15" rims at least because I dont think standard holden 14" rims will fit over calipers on VP on cars, However we have found that 14" sunraisers have a different enough shape to the back of the rim that they will clear calipers on VP. I am running these on the front and if they were brand new would be rubbing on the spring mounts on front struts. For any sort of Offroad action you really have to do something about the crossmember below the radiator. I have seen many of these smashed on rocks and various other stuff. Easiest option we have tried so far is a lenght of 3" channel welded between the chassis rails below/around this crossmember.
  1. Tyres?
    By Spyper in forum General
    Last Post: 13-10-2009, 06:48 PM
  2. [VIC] FS: 2x 205/65/r15 tyres
    By CHEFAI in forum Parts And Other Items For Sale
    Last Post: 13-04-2009, 11:50 PM
  3. WTB: Cheap set of 18 or 19 inch rims - tyres or no tyres...
    By Timzo in forum Swap / Wanted to Buy / Trade
    Last Post: 07-04-2008, 10:56 PM
  4. New Tyres!!
    By elffie75 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2005, 10:30 AM
