Results 1 to 9 of 9
Thread: VT Cruise control drops in and out.
    HSV VT GTS
    Dec 2008
    Default VT Cruise control drops in and out.
    Hey guys,
    The cruise control in my VT drops in and out. I have replaced the indicator stalk, although it was doing this with the old stalk too.
    Will sometimes turn on and sometimes not. also drops out when cruise is engaged.
    Any ideas??
    Bite off more than you can chew, then chew like hell - Peter Brock
    VX Calais LS1, VS Calais L36
    Mar 2010
    Check your brake lights. People who put LED tail lights in have on occasion found the cruise no longer works so it's a possibility.
    Does the cruise have a separate brake switch or does it use the same one as the brake lights?
    HSV VT GTS
    Dec 2008
    Have the factory taillights so not LED's.
    what should i be checking?? I have noticed at night that the brake lights only come on when the pedal travels an inch or so.
    Mar 2010
    Just that they're working. ie no blown globes.
    I'm not confident it's the problem, just an easy to check suggestion.
    HSV VT GTS
    Dec 2008
    yeah they are working fine. might have to take it to Holden
    2000 VT S2 Olympic Ediiion
    Feb 2010
    well at least urs drops in and out mine dont even work when i put mine on lol all globes work though
    VT Calais
    Mar 2009
    SA - Victor Harbor
    my abs used to drop out every now and then for absolutely no reason at all, turned out it was a faulty abs module, it was telling car low trac for a split second, quick enough that i wouldnt even see it, but would make the cruise control stop
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    I have the same problem i just did climate control conversion with loom and now since i have done this my cruise control wont work ,it work fine with my other dash in it but has somthing to do with my dash as i am not getting power to the brake switch b ,they are normally closed when foot is not on the brake so i am guessing if i put 12 v to that it might start working , my problem is that the body loom i put in is a abs loom and my car dont have abs so i am guessing its got somthing to do with that tell the dash low traction etc, telling the car not to engage cruise control i will take a photo of the switch when i have a play but it is supposed to tell cruise control to engage, will update hopfully on the weekend with my findings.
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. VN drops back a gear when speedo drops out
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2006, 12:18 AM
  4. VXII Acclaim Cruise drops out when headlights turned on
    By nevd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2006, 01:09 PM
  5. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
