Results 1 to 20 of 20
Thread: clack noise from rear when handbrake applied
    VT Acclaim Wagon
    Oct 2008
    Default clack noise from rear when handbrake applied
    Seriously, I am getting a CLACK! noise like two pieces of steel being slapped together from the rear right/driver side of my VT wagon when I apply the handbrake at any speed. Why did I use the hand brake? I am trying to get through a NSW blue slip inspection and hand brake test is something they look at. Foot brake is excellent, no noise at all, wheel nuts seem ok. Any hints, clues would be appreciated
    2002 VX Calais
    Apr 2005
    Gold Coast
    all commodores do it when u pull the hanbrake up while moving its the shoes in the hub dont worry about it its normal
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Simple answer...
    DONT PUT THE HANDBRAKE ON WHILE YOU'RE DRIVING.
    The handbrake test should only be to test that the brake is able to hold the weight of the car on an incline should the gearbox park lock fail.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT Acclaim Wagon
    Oct 2008
    SabbathSS, unfortunately, NSW RTA wants the hand brake tested as an emergency brake and use a machine to check it's effectiveness, WHILE THE CAR IS MOVING. I agree with you that the hand brake should only be used while the car is stationary. I have been driving for around 50 years and don't remember ever having to stop using my hand brake. Did you actually read my whole post? I explained why in that.
    brad_m_is, thanks for the info, appreciated
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Graham, mine also gives a bloody loud clack, I believe it's the shoe grabbing the drum. Try adjusting it up to take out any excess free travel in the cable.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by graham7773 View Post
    Thats bullcrap to the extreme (not you, I mean that the RTA want to do that). I find that the handbrakes on these cars only have two settings, full on and full off, to try and get a middle ground would require an extremely good arm on the handbrake. Also I believe applying the handbrake while moving puts a lot of pressure on other parks and can break stuff quite easily, handbrake shoes and brakes mostly.
    Ronald Reagan (1986)
    VT Acclaim Wagon
    Oct 2008
    arcomody, I agree with you but bean counters and pencil pushers have us by the short and curlies, making new rules as they please. On another note, I can't believe how good the brakes are on this wagon of mine
    vt s s1
    Mar 2009
    who is doing the inpection, or are you having to take it to the pits or something? becuause ive never known a mechanic to test the handbrake this way most will tell you what others here have already said.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    what they gna pull handbrakies? and my vn drives lets say 10 metres, rolls like freely, then CLACK handbrake grabs, gotta pull the handbrake 10m before corner entry hhahah
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VT Acclaim Wagon
    Oct 2008
    Hey Pablo, I have the workshop manual and the GMH service manual. There are two adjustments, one in the drum and a cable adjustment near the handbrake. Will be doing them both in the next couple of days....vt s, NSW RTA Blue Slip/pit inspection. Also when a NSW pink slip inspection is done, they put a pressure pad on your brake pedal to measure how much force/pressure is required to stop the car from a set speed. That is when they test your handbrake even on a pink slip inspection
    vn_v6's Avatar
    Aug 2009
    victoria
    wtf arethese pen pushers doing...... whats next, gooch pad so when u brake to hard mesure how much pee comes out?
    May 2006
    Certainly glad we don't have any of this 'yearly inspection stuff' or 'pink slip' drama here is South OZ............The 'seat warmers' seem to think it's not necessary!
    It appears as if all the vehicle crashes here are due to driver error, not leaky sump plugs, noisy suspension rubbers or squeeky brakes.
    VT Acclaim Wagon
    Oct 2008
    I registered a car in SA once a feww years ago. It was a NSW car being reregistered in SA. when I got to the registry, the bloke just looked at the engine and body number and did the rego over the counter. Very simple, very easy. Thought about moving there but too many Great Whites eating swimmers and divers
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    hmm im confused.... there making you do handbrake tests by using it as an emergancy brake which i think is fair enough i guess.... but the new subaru's (could have them in other models) have an electronic handbrake, which you operate by using a button lever thing and can only activate whilst stopped... what are the owners gonna do when they go for a pinkslip down the track ahahaha
  15. #15
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by Cameron P View Post
    lmao my friend had a toyota avalon that had a pedal one... (like where the clutch supposed to be)
    had lots of fun with that =D
    Hit the star under this post if it was any help to you =D
  16. #16
    VT Acclaim Wagon
    Oct 2008
    Subaru trying to stop hoons doing handbrake turns and the like. I had an LH Torana with a foot operated "hand brake" above and to the left of the clutch pedal. Never tried to do any stunts with that.
  17. #17
    99 VT Sedan
    Feb 2010
    Maybe try going to differant machinic.....This brake thing is normal does it in my car to
  18. #18
    VT Acclaim Wagon
    Oct 2008
  19. #19
    99 VT Sedan
    Feb 2010
    All done now, Car is registered and on the road
    How did you get around this situation??
  20. #20
    VT Acclaim Wagon
    Oct 2008
    Apparently, it is almost normal for the VT to make this noise. The hand/emergency brake probably needs adjustment which would get rid of most of the noise but the mechanic passed it anyway. All too confusing.
  1. Brake squeak when not applied
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2008, 02:37 PM
  2. tail lights turning off when brake applied!?!?!?!?!?
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2006, 06:36 AM
  3. indicators go off when break applied ??????
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2005, 10:44 AM
  4. Carbon Fibre: How is it applied? (Not what you think)
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2005, 10:09 AM
  5. park lights come on when brakes applied help
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2005, 04:46 PM
