Results 1 to 7 of 7
Thread: vy engine in vt . but makes a squeaking noise
    Vt V6
    Jun 2010
    Post vy engine in vt . but makes a squeaking noise
    got a vy engine put in my vt and started driving all was good then when i went over 40km'h it started to make a squeaking noise any ideas on why it may be doing that?
    Mar 2004
    Smile More info
    Your going to have to give us more info than that.
    Does it only make the noise at speed?
    Does it make it if the revs are raised while stopped and in Park?
    My guess is the belts squeaking cos they had coolant splashed on them? Spray them with WD40 or similar and if that was the problem it will stop.
    Happydaze's Avatar
    Happydaze is offline Happydaze
    VH SLE T30
    Nov 2009
    GC
    squeaking, ;you would think belts unless its coming from somewhere else??
    Vt V6
    Jun 2010
    i was thinking maybe a pully?yes it only happens when driving at 40kmph or faster . also i went to try out the engine and just before it got to 80kmph the whole ca seemed like it was going to die followed by a knocking sound from the engine/trans ??
    VP Exec
    Jun 2005
    Do you know what type of damage the donor car was subject to eg. rollover and possible oil starvation or possibly a frontal impact to the pulleys/accessory drive or pushed the engine and trans back against the tailshaft?
    Vt V6
    Jun 2010
    not to sure on what type of wreck it was out of?also it seems to be a little laggy. as in while driving it seems to be struggling occasionally to get the speed up
    Vt V6
    Jun 2010
    problem turned out to be faulty leads so nothing major
  1. squeaking noise in air con.
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2011, 11:06 AM
  2. squeaking noise when in gear
    By nagles_18 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2009, 08:21 AM
  3. VS loud squeaking noise
    By jared_vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 03:02 PM
  4. Squeaking noise from wheels.
    By sim_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2006, 08:07 PM
  5. squeaking noise from the engine
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2006, 12:43 PM
