Results 1 to 8 of 8
Thread: ABS and Bettery Light on, any Idea's on the problem?
    VT S2 "S"
    Oct 2009
    Carrum Downs
    Default ABS and Bettery Light on, any Idea's on the problem?
    Hi guys, this morning the ABS light came on then the battery light. The battery light goes out under acceleration, but comes back on when I take my foot off. Any ideas what the problem is?? I have a 2000 Series 2 Supercharged VT "S"
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Hey i never encountered this personally either your abs on the way out or voltage regulator maybe or the alternator is on its way out try and test your battery when running to see if your getting 13.8 v i think i read a post a while back about this and think it was the guys regulator not 100% but that might point you in th eright direction let us know how you go.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Low Battery Voltage can play havoc with electrics. How old is the battery. Maybe try a different battery from a mates car or family member's car and see if it goes away. Otherwise go out and buy a new one if your car has started and sounded sluggish in the morning or if your battery is 5+ years old.
    VX Commodore Acclaim S1
    Nov 2008
    Goulburn NSW
    make sure your battery terminals are clean too. i had an issue with mine giving me silly errors and doing stupid things. some never sieze on the terminals (stops corrosion too) after a good scrub and i haven't had a trouble since.
    Quote Originally Posted by Jecs View Post
    its a nice day for a jog. so jog the f**k on.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by simj79 View Post
    Check it with multimeter...check the main positive behind the alternator......
    If not charging correctlt.....you could change voltage regulator...But in my case i done this..But inside of alternator was stuff making a washing machine sound...So i put a new alternator in...all good
    VT Executive S2
    Jan 2010
    Illawarra
    Default Airia
    i have had that problem before ,mine was my idle speed not being high enough.Made it higher fixed the problem.
    *uwishn* is online now Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Default hi mate
    when mine was on was the abs module normally it is when them 3 start coming on.
    VT S2 "S"
    Oct 2009
    Carrum Downs
    Thanks for the help guys, the prob was the alternator, seems it was pumping out more volts than it should have been 16+, this must have been just as the mechanic got it, as it had a flat battery in the morning, but is all sorted not, quick reco and all done. I had the ABS problem last month, that was the followig lights, ABS, TRAC control and Engine. I seem to have had 3 things in 3 months, hopefuly it stops there.
  1. 2001 ute fog light head light problem
    By dayzee88 in forum Electrical Wiring / Questions
    Last Post: 29-12-2009, 07:35 PM
  2. Help me with idea's please
    By aussieben in forum Car Audio
    Last Post: 07-09-2009, 07:17 PM
  3. Dead Bettery Central Locking
    By Robert105 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-05-2009, 05:59 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
Tags for this Thread
