Results 1 to 17 of 17
Thread: what have i done????
    98 vt s pac
    Feb 2009
    Corowa NSW
    Default what have i done????
    hi i changed the spark plugs today on my vt and now when i start it, it shakes and shudders really bad until i drive it for about 40 seconds then its fine, until i stop and start it again and it shakes and shudders like hell. how could changing the plugs do this? and why does it go away after a driving for awhile?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check all the leads to see if they have clicked back on all the way.
    MY RIDE
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Maybe you've cracked one or more of the leads, or half pulled an end off one of the leads/damaged them as you were removing the leads to change the plugs?
    I was doing the leads and plugs on my neighbors VT and one of the leads had like corroded/rusted onto the plug. When I went to remove it, the end of the lead styed there, while the lead itself came out in my hand :/ lol...
    VT 308
    May 2010
    98 vt s pac
    Feb 2009
    Corowa NSW
    ok checked the leads and they all seem ok? the missus just drove off and you can hear it missing really bad
    Zeussy's Avatar
    Dec 2008
    Central Coast
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by mynameisearl View Post
    On my old car vr v6....I had new spark plugs on for only 1000 km.....Until same thing happened to me ....Car started shaking...And feel like its missing???.......
    I don't know maybe one plug is faulty???
    I read on one post a few months ago......"look at your engine while running...In the dark"" maybe you will see a spark jumping????
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by 11gothevt11 View Post
    But than again...when i changed my spark plugs after 1000km...maybe it had something to do with my leads..I might of pushed them in more...or something
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Yeah mate. Fully check your plugs, and if they are all ok I would get a new set of leads
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    hey guys that happen to me once with my old vn i did a service on it and it was the 1st service i did on it being my 1st holden ever so i naturally went to holden and brought plugs and it turn out to be the plugs from holden 2 of them were stuffed ,best way to tell what cylinder it is if you can get to the injectors plugs pull them off one at a time and see weither it makes a difference if you take one off and it runs more rough than what it was its not that cylinder but if you unplug one and it remains the same its probably that cylinder playing up and if that dont work oh well throw a spanner at it
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I would say it is a faulty spark plug because a faulty plug will sometimes come good once it is warmed up.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    i'd take bhoppers advice.. but use moulded plyers lol or you might get a little zap ahaha.. some might say thats common sense but i have seen a guy do it lol
    i had the same problem and thats how i diagnosed it
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by Cameron P View Post
    i would check the gap had same thing yers ago , plugs had wrong gap car ran like shit
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by gungazza View Post
    i put exactly the same plugs in as the originals? changed all the plugs one at a time this morning, made no difference still runs like crap? how could putting new plugs in make the car run like shit!
  15. #15
    VT Series 1 V6
    Jan 2008
    I'd get a diagram and make sure that the leads have been put in the correct order. If so, then take the plugs out and check for cracks in them. It's very very easy to crack a plug even without over-tightening them.
  16. #16
    98 vt s pac
    Feb 2009
    Corowa NSW
    well i gave up and put the old worn plugs back in and it runs fine now....
  17. #17
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    check the resistance on each lead, even new plugs can fail thats the best way 2 rule out the leads. but sounds like its the plugs if the old 1ns work lol.
    try swap 1 new plug over at a time with the old lot and see if that makes a difference? if not then go 2 the next plug with another new plug and u'd rolly find ur faulty plug/s
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
