hi guys i just put 1.9 ratio rockers in my car and now its got a slight ticking noise that wasnt there before any experienced help would be great, i torque set them properly and also cleaned eveythin so im lost.
I would check that the push rod isn't hitting the guide plate the rockers sit on.
When I did mine, one of the rods was hitting the plate.
Easy fix, just loosen the screw and slightly move the rocker to adjust the rod away from the plate.
Hardest part is finding out which one it is, although it probly will b marked now from rubbing.
Anyway, thats was wot mine did![]()
Stoke my ego, click the scales!!!
Stoke it!!!!
LOVE IT!!!!!
thanks alot for that mate was something else i looked for when i started again today and went over everything , it was all fine but i retightened everything and took my time only thing i did different was not tighten the covers to the torque setting i just did them by feel plus a bit more pressure and its all good now, thanks for the help.
