well just got back from the mechanics after the car ran like shit after putting new plugs in and having it run like shit, they say there's oil leaking into the radiator? which means the the motor is rooted apparently and they said with the car having 280,000k's on it its a waste of time fixing it and that i should replace the the motor. How much am i looking at for a replacement motor and getting that put in?
between $500,$1000 bucks ive seen them going for, then a couple hundred for labour if your gonna get someone else to fit it.
^^ sounds about right. Try the wreckers as they often have a fitting service for second hand motors.
and 3 Dangerous non ABS VN's
thanks fella's
was told about $3000 by the mech so these post have given me hope lol
ive seen ecotecs with less than 150000k's go from 200-500. 1k will get you a whole doner car
got quoted $950 for VX engine with 103,000k's on it from the wreckers with 6 month warranty that sound about right or should i stay with the VT?
Hey i know what your going through but unless you can see the engine in car you would never know how many klms are on it and 2 from experience when they say theres bugger all klms on it somthing must be wrong unless it come out of a crashed car that been sitting in a yard for a while ,i got my misses sister a motor that supposably had 60 thou on it and ever since the day i started it, smokes a bit runs fine but smokes a bit so who know ,10 000 only just ran in or is it 10,000 since a rebuild these are things we have to worry about when we buy engines.
definitely go the vx engine, warranty and it would be that little bit newer.......before you do, thrash the old one :P
yeah go the vx engine mate, they also have 5 or 6 more kw standard then the vs/vt motor
