Results 1 to 5 of 5
Thread: climate control conversion a success not so hard as others say
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Default climate control conversion a success not so hard as others say
    Hey guys i just finished my vt and put climate control in it ,i have been reading for months how people thinks its hard ,not worth it etc well i paid $149 for heater box and body loom and off i went 12 hrs later i have climate control, looks awsome with blue leds and the calais dash and now have all the little extra features of a calais, berlina. I was guna just spider it into my loom but my heater need replacing so i thought while it out i will do the whole loom.
    Just a few pointers if you are guna try it ,well i compare the job to doing a engine swap the only hard part was the actual relay box in the engine bay well that can get you cursing ,you have to remove all the relays and the fuses and i would recommend tape the whole relay block up with grey electrical tape to help hold and protect the wires while going through firewall if you can have 2 people for that part.
    now i am guna try my little bro's vt and try and spider it into a standard loom and standard heater box and all you have to have is the vacuum switching block of a climate control box unless you wana swap your whole heater to climate control box ,as there is one electric actuator on the bottom for selecting hot and cold but the rest should be easy ,i have work it all out how i am guna do it and fingers crossed that it will work with a bit of soldiering to the climate control module for air con to switch on but if you dont want or care about aircon well its easier than we all think. i will try it in the next few weeks and i will do a write up on it but look out for my write up if its possible or not.
    The hardest part about the module is the actual aircon request wire on a standard loom there is a wire that goes from standard air con switch but in the calais-berlina they have been tricky and change it to the serial data wire which send heaps of info through that wire that communcates with abs,srs dash climate control pcm etc so there no way of getting a pulse from that wire.
    So you can just wire that in like the standard looms ac, i am going to find a point in the climate control module to get my ac request and hopefully it will work . so stay tuned and look out for it when i do as i am eager to do it and maybe make kits up for sale if you are really wanting it but cant be stuffed trying to work it out.
    Wish it was as easy as the vp just wire it up and go, but once i figure this out it will be as easy as that.
    bhopper
    vl wagon
    Jul 2009
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Good on ya. Everyone says it is too hard because we can't be bothered nutting it all out like you have.
    A write up with keeping your standard heater box and a full conversion would get you some pretty good rep around here I think.
    Many people would give it a go if they had some comprehensive and easy to follow instructions to help them along the way. And selling kits is a great idea to speed things up.
    I for one once bought a conversion kit, but seeing that the heater box was broken was enough for me to sell it again in seperate parts without the heater box (for profit hehe) and give up on that idea.
    Dec 2009
    east of melbourne
    Cheers fellas well i wont rest until i have done the actual conversion to a standard box ,i cheated with doing the loom but it was there so i thought i might as well do it while i do heater core but of your air con is all good be a pain to have to get it degassed and regassed ,get new bcm ,keys and link up with pcm ,so i will knot this one out ,i only got a hold of some good info the night i put it back together but stay tuned i will beat holden at there own game .
    VX II SS 6pd
    Aug 2010
    Mooroolbark
    Possible if you could give a rough explination/tutorial here eg, parts, features and where everything goes
    If possible would you please post any links if possible in relation to your conversion as i am egar to try this myself
    That or send me a pm
    Much appreciated
  1. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  2. climate control,how does it work need to know for climate control conversion
    Last Post: 09-07-2010, 12:49 PM
  3. climate control conversion
    By roger05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2009, 04:19 PM
  4. Climate control conversion
    By FXST01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2007, 08:58 AM
  5. Climate Control conversion
    By djpunkasspete in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-08-2005, 10:07 AM
