Results 1 to 9 of 9
Thread: VT loud clunk,now it wont turn over
    vt commadore
    Jun 2009
    Default VT loud clunk,now it wont turn over
    Hi guys ,the wife went to leave for work today,
    the VT made a loud clunk noise as soon as she twisted the key
    so now when you twist the key you can feel/see the starter try to turn the motor but its not happening(motor will not move at all)
    tried a fresh battery =same problem
    what should i be looking for?
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    1. Check the power and earth to the battery, clean the terminals.
    2. Put a shifter on the harmonic balancer bolt and try turn the motor over. Could be siezed but i doubt it.
    3. Check the earth and power cables on the starter motor. Sometimes they come loose.
    4. Change the starter motor.
    VZ Maloo. 6 Speed. OTR. Tune. Some other bitz
    Jul 2010
    All the drive belts are on yeh stupid question but still..? Clunk sounds wierd as.. iv never heard of that before
    vt commadore
    Jun 2009
    Just been out and chacked the oil and its milky
    any advise on where to get some reco heads?
    VT V8 berlina
    Jan 2010
    might just be head gaskets??unknown tho till you pull them of and test but just maybe 1 or more cylinder is full of water and she has started to hydrolic.hard to say without looking but if you take out your plugs and try turning it over see if any water comes out..just a thought.
    Sep 2005
    Did you try and turn the motor over by hand or what? If its hydrolocked then you could need more than just a set of reco heads lol.
    vt commadore
    Jun 2009
    Quote Originally Posted by IBLOWN View Post
    yeah i turn it over by hand,and it was really hard on one cylinder but top dead center on the other five felt fine
    i got it going(running rough)
    and when i chek the oil thismorning oil is milky
    so i guess the next step is to take the heads off and see what im dealing with?
    Sep 2005
    Quote Originally Posted by budgienutz View Post
    I'd be doing a few more checks before going to that extreme. Do a compression check and also a coolant pressure check first.
    vt commadore
    Jun 2009
    kk will do
    thanks again for the help fellas
  1. 5l wont turn over
    By Uber_Matt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2009, 08:00 PM
  2. loud clunk in the front end of my vu ss ute
    By _mattyboy_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 10:28 AM
  3. Hearing Very Loud Running Of Fluids After I Turn The Car Off..Help?
    By social in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-11-2008, 07:54 AM
  4. Wont go loud!
    By bognog in forum Car Audio
    Last Post: 23-10-2006, 10:05 PM
  5. loud rattle now car wont start
    By executor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 06:24 AM
