Results 1 to 7 of 7
Thread: VT Just dies and won't restart
    2000 VT Commodore
    Jul 2010
    Default VT Just dies and won't restart
    Hi,
    I have a 2000 VT Commodore that just randomly dies and sometimes won't start.
    On average it seems like every two days the car dies while driving. There is no noise or any warning. It is as if some one turned off the key. The engine light comes on. The car then immediately starts up again but sometimes the engine light stays on. Some times when you go to take off at the lights it will misfire a bit but then recover and keep going.
    About every two weeks the car won't start. It always starts when leaving home but when you leave from where ever you have driven too, sometimes you're there 30 minutes other times 3 hours, it won't start. Sometimes if you try for a while it will start after about 20 minutes. Most times the car has to be jumped. Then it drives home fine.
    The car has had its fuel pump, fuel filter and computer replaced. I have gone around the car checking all grounds. I cannot see any obvious wiring faults and most of the time the car functions as though the starter and alternator is fine.
    From here I can only think to start replacing parts but I thought I would get your opinions on what might cause these sort of issues.
    VT Commy
    Mar 2010
    Adelaide!
    Well i don't know anything about anything! so i wont be much help :} uhh..did you check the battery also?
    2000 VT Commodore
    Jul 2010
    The battery is new, well was new, the being jumped all the time is making it age quickly.
    Dec 2005
    day mate,
    My VT did this very same ting a while ago, it ended up being the fuel pump in the tank, I thought maybe the body module as well, so replaced the module.. but in the end fuel pump.
    vr calais vt berlina
    Jul 2008
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Im with lestat seem slike the crank angle might be overheating and wont function poperly until it cools down next time it does it pour some cold water on it when it does and see what happens. i had a mate who car did this so he just poured cold water on it and it would restart until he fixed it.
    VT S2 "S"
    Oct 2009
    Carrum Downs
    Def sounds like the crank angle sensor. Cold water will help it, but it will tend to make the problem hapen more often. It is an easy fix and should only set you back about $110 (and that is from Holden, supplied and fitted)
LinkBacks (?)
  1. 09-10-2010, 12:33 PM
  1. Updated Bios - Restart Computer?
    By Evolution_Ends_Here in forum The LAN Lounge
    Last Post: 04-08-2008, 07:43 PM
  2. VS stalled and could not restart
    By davros in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2008, 06:04 PM
  3. How Do i restart the computer on the vn ?
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2006, 02:05 AM
  4. Engine dies on warm restart
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 07:27 PM
  5. vs cuts out when driving and is hard to restart
    By spazgazz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2005, 01:29 PM
