Results 1 to 3 of 3
Thread: VT 5L oil pressure problems
    vp s2
    Apr 2010
    Default VT 5L oil pressure problems
    Hi guys and gals, This has probably been discussed before. I have a VT SS 5L. The oil pressure light came on and then tappet noise. I changed oil pumps, took sump off and cleaned pick up filter, new gaskets, oil etc. Oil pressure good now at medium to high revs but warning light comes on at idle with no oil pressure.
    Any help is much appreciated, Cheers
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    maybe clean/ replace the oil pressure sender. what weight oil are you running? a few mechanics have told me oil around the weight range of Penrite HPR 30 is good for a 5L thats not too flogged out. maybe HPR 40 if its done a few kays and had a hard life
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    vp s2
    Apr 2010
    Thanx dirt drifter. Motor A1 condition and tried new sender, new pump & filter, new oil 20w50. Bottom end all ok. Might have to look at installing a mechanical gauge maybe so I can see exactly what is happening at idle. This baby might end up on the fire heap.
  1. 5lt oil pressure problems
    By millaz88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2010, 08:59 AM
  2. Fuel Pressure Problems
    By 2001_VXSS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2008, 09:04 PM
  3. Oil pressure problems
    By jsracer024 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2008, 09:34 PM
  4. Fuel pressure problems
    By sik sv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2006, 10:51 AM
  5. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
