Results 1 to 6 of 6
Thread: Rear cradle subframe mount?
    VX s2
    Jul 2006
    Default Rear cradle subframe mount / Castor ROD (new question) :P
    Hey guys i got my car back from service and they have quoted me up some concerns.
    it's a 2000 vx berlina . I plan with a friend to tackle these problems myself and try to avoid the $700+ labor they quoted. The only part i can't work out is "Rear Cradle sub frame mount are starting to tear".
    I have a look under the car but can not see what they are talking about. Can someone show me a picture of where this sub frame mount is ?
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    I hope this link works, but it is under the bracket in picture: http://i708.photobucket.com/albums/w...r/RIMG0393.jpg
    This bush does not need to be pressed out, you can pry it out with a decent flat bladed screw driver.
    I'm pretty sure it can be done while still on the car, you would just need to lower the sub frame assembly enough to awkwardly get it out and put a new one in. these would do fine: Commodore VP VR VS VT VX VU VY Crossmember Outer Mount - eBay Control Arms, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 10-Aug-10 21:04:03 AEST)
    Just push it in like the old one, then put the spacer in before you bolt it back up. These are meant to be better thatn the oem part and longer lasting.
    The rear diff mount will need to be un bolted as well. You will need a cradle alignment as well as a 4 wheel alignment after it is done, so there's another $150
    VX s2
    Jul 2006
    Hey guys
    I have to get new castor rod bushes too ...
    Can anyone show me what bushes i need to pick up on ebay . I know the front ones are http://cgi.ebay.com.au/ws/eBayISAPI....fvi%3D1&_rdc=1
    but the rear one in this picture
    DO i need this one, want to make sure ? http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
    VX s2
    Jul 2006
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    The inner pivot bushes for the control arm: Commodore VT VX Nolathane Lower Inner Control Arm Bushs - eBay Other, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-Aug-10 19:04:43 AEST)
    these usually wear first, so replace them while you are at it. There are 6 bushes in the kit, but you only need to use 4. 2 are exlusivly vr/vs and two vt/vz.
    I couldn't find the one you have circled, but it is the strut bar to control arm bush, online performance autos have them, they will probs come up soon.
    stevieVT's Avatar
    stevieVT is offline The apprentice
    1998 VT berlina
    Mar 2009
    central coast, nsw
    that bush you have circled is called the radius rod bush....replace both this and the castor bush at the same time
  1. Changing the rear subframe/k frame YAY!
    By CommodoreAdict in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2010, 02:28 PM
  2. changing vt rear cradle to a vx series 2 cradle problems
    By TIN_MAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2010, 10:25 PM
  3. Wanting to fit VR-VS rear subframe into VP IRS
    By vp_exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2010, 05:53 PM
  4. Cracked rear subframe
    By toolbox1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 11:33 AM
  5. URGENT: Where to mount Car kit cradle on my VX
    By thisispete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2005, 06:15 PM
