Results 1 to 6 of 6
Thread: problem with my vt ss gen3
    VP Executive S2
    Jul 2005
    Default problem with my vt ss gen3
    hi guys
    Im after some help with my gen 3 its not charging the battery again its got a reco alternator in it and it not even 12 months old was wondering if its stuffed or clogged up with powersteering fluid if it is clogged up how can i go about getting it charging again has anybody had this much trouble before its like my 4th alternator in just ova 2 years
    VX lumina
    Jul 2008
    SE Melb
    3 main things i would be looking at..
    1. is your power steering leaking?
    2. are the alternators being rebuilt properly?
    3. check the battery regulator
    SSZ 5.7LTR & 01 VX V6 Supercharged
    Aug 2009
    Toowoomba
    Geez you 2 are up early ^^^
    Have you put a multi meter across the treminals? I assume you have being your on you 4th alt, by memory it should be between 13.2-13.7 Volts.
    Also check the earthing of battery and alt, and are you belts in good shape.
    00 SS M6/79 chev Monza
    Mar 2005
    I bought a vt ss that had 3 alternators replaced in 2 years (before i bought it) each one was damaged by leaky power steering rack (constant topping up of reservoir and spillage ending up on the alternator ) change seals on pipes in the rack cleaned up all oil mess in the engine bay and all is good
    VT II Clubsport R8
    Jul 2010
    How does leaking powersteering affect it? I believe you but am curious to know, the windings are enamel copper wire
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    ah yes, but the terminals aren't, and neither are the brushes. It's an inherent design fault, low alternator too close to the leak prone steering racks.
    I haven't lost my mind, it's backed up on tape somewhere
  1. vx gen3
    By cruza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2010, 10:03 PM
  2. gen3 in to a vp????????
    By almc04 in forum Projects
    Last Post: 11-08-2008, 08:04 AM
  3. My GEN3 LS1 Vp SS ute
    By tmdestruction in forum VN - VP - VG - VQ
    Last Post: 08-07-2008, 01:58 AM
  4. To buy a Gen3 or not
    By ashbox in forum General
    Last Post: 29-04-2008, 08:35 PM
  5. Is gas bad for gen3
    By greatone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2006, 06:08 PM
