Results 1 to 3 of 3
Thread: Ingition VT
    2002 vx wagon
    Mar 2009
    Default Ingition VT
    When I start the car the key doesnt return and I have to turnit back myself or the starter keeps engaging
    Is there a spring or something that can be replaced
    I had the same problem with my VX and the auto elec charged me $80 to fixit
    This time I would like to have a go my self and save the $$$s
    seem like a common problem
    Any ideas
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The spring part is in the ignition switch so you will need to replace the switch.
    MY RIDE
    buying a VT berlina
    Nov 2009
    Yes replace the ignition before it goes from not returning to doing nothing cause the end of it has crapped itself, its an easy fix but can be costly if it means you cant get to work till you fix it.
    take off the shroud around steering wheel.
    put key in ignition
    put allan key in small hole at top of ignition
    turn key and pull outwards
    you should have the ignition assembly in your hand attached to your key.
    take it into a locksmith and get him to replace it, $60 and 15 mins later you have a new one in hand
    goto car, inspect inside of ignition for any loose parts (important)
    remove them if needed (if you cant get it out that side you need to get your allan key onto the other side and remove the switch part of the assembly)
    once all is free of broken parts etc put it back in and it should lock into place, allan key may be needed on the top again.
    enjoy your new ignition
    tis common for the end of the ignition assembly to snap and leave your key useless. you may have just had a break far enough in to upset things without disabling your car
  1. Ingition questions
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2009, 05:21 PM
  2. ingition module vs v8 wiring diagram
    By whonxt in forum Electrical Wiring / Questions
    Last Post: 26-02-2009, 05:32 PM
  3. Anyone need an Ingition Module repaired?
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2006, 01:04 PM
