Results 1 to 15 of 15
Thread: Fan's not starting up
    VT Commodore
    Jul 2010
    Bundaberg
    Default Fan's not starting up
    Hey
    I've read a lot of threads about this on the forum however am slightly confused by it all.
    I've noticed my fans just don't boot up. Even after 15 mins of running with air con on.
    I can cheat and boot them up by unplugging the sensor wire from thermostat housing.
    So I assume it is the low speed relay. Is there a way to test this?
    Any other suggestions or comments
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    VT Commodore
    Jul 2010
    Bundaberg
    Unfortunately I dont have a working multimeter around atm. I placed a wire between "30 and 87" and the fans booted up. So would that rule the relay as faulty?
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    He there matt yeah go to holden and get a relay ,dont get one from supercheap or anywhere as the pin setup is different from what i have read myn did the same but i had a spare one from a wreck i had and it fixed the problem ,also when you unplug the temp switch and they turn on it dose indicate your wiring is functioning and is all ok ,the low speed should turn on after 6 sec and the high should turn on after 10 sec ,so if its not relay may be temp switch not sending signal to turn them on.
    cheers bhopper
    VT Commodore
    Jul 2010
    Bundaberg
    Dec 2009
    east of melbourne
    Hey no idea could be anywhere from 12-25 just ring spare parts and while your at it get a price on the temp switch they can be expensive when i got one last christmas i got a temp switch for 75 but they were usually 120 for temp switch just have to get a good sales person i think.
    VT Commodore
    Jul 2010
    Bundaberg
    OKay I got a new relay.. $12.50
    Im confused... My car doesn't over heat. The gauge sits under half way like normal.
    The only reason why Im thinking the fans aren't working is that I don't hear them fire up any more. Eg Mcdonalds drive through.
    Now I understand the fans come in on at 104c. I sit the car running for 20 mins and nothing.. Got my mates vt and sat it running for 20 mins and his didn't come on either. How do you actually test the temp of the engine to see when it hits 104c?
    How long from a cold engine will it take for these fans to come on at there own will?? approx anyways
    Grrr I dont no if theres something wrong or not
    VP Exec
    Jun 2005
    The fan low speed should be on with the A/C (@ < 30km/h) so that would suggest that something is not working right but it may take a while idling to get above 104C in winter temperatures if you are looking at that.
    At 100C the coolant temp sensor should have a resistance of 180 Ohms, @ 104C it should be a little below that so if you can find a DMM you might measure that.
    If you put a pot/variable resistor across the coolant temp. sensor harness terminals and run the resistance through the just less than 100C/180 Ohms value, the low then high fan speeds should switch on, so you can see if both work not just the high. It would be sensible to use a fixed low value - 10 or 20 Ohm - resistor in series with the pot to avoid even the possibility of a short across the sensor.
    VT Commodore
    Jul 2010
    Bundaberg
    Hey my air con doesn't work at all so I cant do that test :-(
    And I dont have a multimeter to test the ohm's
    Grrr Any other ways ?
    VXII
    Nov 2009
    Your a/c doesn't need to work to test it. Just bridge the terminals on the pressure switch to test the fans. The compressor might turn for a moment, but it shouldn't do any harm for a few seconds.
    Also, you can safely short out the coolant temp sender wire to test the fans. There's no need to use a resistor inline.
    Dec 2009
    east of melbourne
    Hey matt not shore about shorting them out but as i said if you unplug the connector on the temp switch and they start up the wiring is all fine ive also had to do one of those myn starting to play games like after 30 sec of car starting they would switch on and not turn off ,not turn on at all etc , just before myn went the fans used to switch on after 5 mins of idling but once it shiy itself the fans wouldnt turn on for easy 20- 25 min also have you tried the special features on your dash to see what temps the car is running.
    VT Commodore
    Jul 2010
    Bundaberg
    Hey whats the special feature again. Cant remember the procedure? Ignition then hold down the buttons?
    '98 vt berlina
    Feb 2010
    Quote Originally Posted by bhopper View Post
    cheers bhopper
    hey matt, like bhopper said, when you unplug the temp switch did you notice the fan turn on at slow speed first before going fast? if not your slow speed isn't working.
    VT Commodore
    Jul 2010
    Bundaberg
    Quote Originally Posted by tk55 View Post
    yes it works slow and fast with the themo wire unplugged..
    Yeah i wanna test this temp thing out .. Whats the procedure?
  15. #15
    '98 vt berlina
    Feb 2010
    at the speed alert module, hold down the mode and up-arrow buttons while turning on the engine. keep holding the buttons until you heard a few beeps and the display changes to show something else. let go the buttons and scroll through the display with the up arrow (or was it the mode button can't quite remember) until it shows the temp.
    usually the easiest method to tun on the slow speed is simply to turn on the air-con. but since your air-con doesn't work you have to wait till the temp hit the 104 deg mark. in this winter, you're going to have a hard time getting the engine to that temp. my ex-vt only get pass that temp when in a traffic jam situation. i guess you can ramp the engine while sitting idle for a few minutes and see if it does it.
    alternatively use the resistor bridging method to test it, as described previously by others.
  1. Both Cooling Fan's Not Running? Help
    By nick713 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2010, 08:55 PM
  2. VR Bad Starting
    By djlingard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2006, 10:23 PM
  3. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
  4. not starting
    By rbrtm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-10-2005, 05:09 PM
  5. thermo fan's
    By raymondzss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2005, 09:05 PM
