Results 1 to 3 of 3
Thread: Air/Fuel Gauge
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    Default Air/Fuel Gauge
    So finally after 3 months i got my air/fuel gauge. I plugged it in to the power and now it's looking nice and pretty... i know which sensor to connect it to but i don't know which wire!on the O2 sensor i have 4 wires. It looks as though there are 2 brown wires, 1 purple, and the last one i can't make out if it's pink or light brown. but ye. i tried on the purple wire but didn't get a reading, it just said 100% lean. i'm too scared to try the other wires in case i get the positive or something and burn it out lol. this is a digital gauge by drift. any help is appreciated
    Feb 2010
    sorry i should also mention that with the sensor completely disconnected the reading is still 100% lean. cheers
    VP Exec
    Jun 2005
    To save you the search:
    LHS: +ve is violet/black trace, D16 @ the PCM (=> signal on the gauge)
    -ve is violet, D15 @ the PCM (=> [signal] earth on the gauge)
    OR
    RHS: +ve is grey/black trace, D14 @ the PCM
    -ve is grey/yellow trace, D13 @ the PCM
    Use both the sensor +ve and the sensor -ve for the gauge inputs as the voltages generated are small and any difference in voltage (potential) across the wires can affect the reading on the gauge. i.e. avoid using just any convenient earth for the signal earth if you can (and you can).
    The power and earth wires for the gauge operation/lighting won't be critical so you can use pretty much any convenient ignition and accessory power source and body earth.
    Wiring for S/C V6 is different to NA V6.
    The pink wire @ each of the sensors is the power wire to the O2 sensor heater, B+ve with ignition on. The black/red trace is the heater earth.
    If you made two pairs of pigtail wires, spliced into the wiring for each O2 sensor near the PCM, with male/female connectors (available from Jaycar or similar eg. two of PP-2062), you could easily unplug/plug and swap the gauge from reading one bank of cylinders to the other.
    If you remove the connectors from the PCM and remove the plastic back out prevention combs from the terminal blocks you will be able to see the pin letters and numbers cast into the plastic terminal blocks. Splice into the wires 100mm or so from the PCM.
    Better luck this time .
  1. Fuel gauge or Fuel sender?
    By Defected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 03:19 PM
  2. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  3. Faulty Fuel Gauge/fuel pump unit VU SS ute
    By paul.stewart2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2010, 09:48 PM
  4. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  5. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
