hay everyone
just thought i would get peoples suggestions on what mods i should do to my ride
its a vx ss 6 speed with tri y`s into twin 2.5" pipes with only the 1 middle box for each pipe not sure if i got high flow cats or not wouldnt mind putting a otr cai plus a mild cam n roller rockers
cheers
Whats the budget?
no sort of limit at the moment just open for sugguestions
For starters it depends what sort of power you're after.
I started off with exhaust,a couple of months later I got it tuned and changed diff gears (mine is auto) and put a nice otr on it. This should make easy 300+ rwhp which is quite nice over stock.
After that I'd start thinking about a cam change,but again it mostly depends on your budget.
well my next thing i would like to do is a otr cai and roller rockers than a maffless tune ?
No need to do rockers. Get a good quality OTR, if you don't have hi-flow cats (get your checked) get some and then get it mafless tuned. If you have the funds and want to do it all at once, get a cam. Depending how hard you plan on driving it and the size of the cam, you may need to look at an upgraded clutch too.
was only going to get these 1.8:1 High Ratio roller tip rockers is to replace the standard lifters as i heard they tend to start becoming noisey? is this true but will get the cats check as soon as possible and will they make the note any louder
Hi-flow cats will usually make the note louder and deeper. By all means change the rockers while you're at it, I was just saying it's not usually a mod done first up.
