The steering on my Senator has become really light all a sudden. Thought it was a little heavy when I brought it 6 weeks ago, but now for no apparently reason that has changed. Even at 100kph it was light, far too agile.
Power steering fluid is fine. Haven't checked it for leaks underneath yet, as it only happened today. Apparently the steering rack was only recently replaced. Dash fuse was fine too. What's causing this ?
Do you know if it has speed sensitive steering? I would be checking that it is working. Being light at 100k seems to indicate that it is not.
Hmm, I believe variable power assist steering is standard on VT's. It seems there's no leaks, as there is no drips on the ground. Need to jack it up to look properly. It just seems so easy to oversteer at the moment.
I remember having this discussion with Minux, he said the senator did NOT have the variable steering (I questioned this because I thought it was based on the Calais), but he was pretty confident it didn't.
50LTRv8
Senators definitely use Calais as the base model to start with. To weather they have the variable power steering is unclear from the information I have researched.
Does anyone know how you can tell ? As I said the characteristics of the steering have change all a sudden for no apparently reason.
VTs with speed sensitive steering have a rotary valve body on the driver side of the steering rack. This contains a solenoid assembly (and flapper valve) with wiring harness connector that connects into the ABS loom. The power steering pump for speed sensitive steering has a different part number to the standard pump - for a V8 it is 26056056 located on the back of the pump. Sounds like you may need a replacement solenoid assembly.
When I brought the car it had a leak at hose at the back of the reservoir. I only had to adjust the hose and tighten the hose clamp to fix the leak. I have read that it can take some time for the pressure to build up to get the power steering working properly again. Took 6 weeks, but hopefully it all good.
According to my VT GM service manual, speed sensitive power steering was standard on Calais and optional on other models
yes but the vt gm wouldn't cover hsv's would it? the easiest way to tell if you ahve variable steering is like blackvxgts states.. check if there is a loom coming off the steering rack
Finally got a good look at the power steering rack. I believe the two wires in the pic confirms that my car does have variable assist speed power steering. Problem is, I believe the rack is leaking now. Just not sure where.
Certainly does have variable power steering.
Those solenoids have a tendency to give up, replace it and I'm confident your issues will be sorted. Had a similar issue on a VR.
The rack may have blow a seal out after the solenoid gave up, due to the fact that you would have been forcing the rack. Nothing you could have done short of not drive it, which I can understand isn't possible for most people.
My opinion anyway.
