Guys,
bought the car not even a week and this think just happened to me this afternoon
anyway, when i unlocked the driver door, the lock didn't come up all the way. then, i tried to use the key to unlocked but could not even turned the key..
well, what cause the problem? how to fix it?
Thanks in advance
Oh, forgot to add, i can open the rear doors by using the remote and open the driver's door by pull the lock up manually
cheers
Sounds like the door lock/actuator has thrown in the towel.
but, how the other 3 doors working when the master dead?
MY RIDE
Yeah mate, sounds like the door actuator. It was happening to my vz about a month ago. You have a few options:
-get a new actuator from holden which will cost you $169 and either get them to fit it for about $200
-get a actuator from the wreckers for about $60 and put it in yourself (Fairly easy, take your door trim off and replace the actuator there is a how to here )
-take the door trim off and give the actuator a clean and spray some lube on the moving parts, this what i did, cost me nothing and its working great.
hope this helps
ZOMBIE
Thanks mate, i'll look into that on my next day off and thanks for the DIY link too
had a similar issue on my car ,turned out one of the wires in the connector was loose ,fixed that now no issues with it whatsoever ...........i do however have a spare actuator because that is what i thought the problem was !
ok guys, managed to have spare time to fix this problem.. but turned out it was not the actuator, it was the rod that connect from the actuator to the lock button ! once i removed the button and left the rod there, the actuator is working perfect and no matter how many time i tried to lock and unlock the driver door, it never had problem.
i realised one thing, when i tried to put the lock button onto the rod, it fairly tight!! and and that make it a little stuck there
already tried to bend the rod abit, but still not fixed the problem..
it more like,,, when i unlock the door, the button wasn't up up all the way, just got stuck there abit , sometime the door can be opened but it felt it stuck thru the outside door handle
what can i do to fix it? any help?
anyone? any other inputs?
