Hi guys, OK I am having a little bit of trouble trying to work out where the link my new vacuum gauge, vacuum line to? i have a ls1 engine and i can see that it might be possible to run it in to one of the air ports at the throttle body using a T piece joiner but I'm not sure or weather it will give a good reading or not. the gauge is for show but i want it to work! anyone with any ideas or have put this gauge on there ls1? pictures and desc would be great!!! thanks
there is a small line that comes out of the back of the manifold and goes into the heater inside through the firewall use a t piece and join it in below the little white and black one way valve.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
