Heya I have a VT and when I change from Park into Drive there is a loud clunk and the transmission kicks. It also does the same throughout every gear although the kick gets smaller the higher the gear. I have replaced main solenoid and problem still exists.
Any ideas?
Thanks for your feedback.
You got enough fluid in it.
yeah fluid topped up, it now takes off in second gear
i had that problem in my skyline a while same type of noise just a suggestion check the front and rear uni JOINTS as thats what my problem was
