Results 1 to 4 of 4
Thread: replacing globes in ac/fan cluster on dash
    Commodore VTII Acclaim
    Sep 2009
    Rooty Hill
    Default replacing globes in ac/fan cluster on dash
    imsorry if this has been posted before, but ive searched and could not find it. i suspect i need to replace the globe in the fan/ac cluster as i have no lights behind anymore. the light in my gear shifter had gone out but i gave that a tap and it cam back on, but now the fan cluster is not working. how can i fix this. thanks. Jason
    VY SS
    Jun 2006
    Albany
    to get to the globes you have to remove the panel around the gear stick, there are 2 screws in that pocket thing under the headunit then the centre panel should lift up. next you have to remove the upper panel which is around the gauges and everything, there are 2 screws above the gauge cluster then you have to drop the fuse panel under the steering wheel and you should see some more screws holding that upper panel. once all those screws are out you can pull on that panel and disconnect the headlight plug and trip computer controller and the whole panel should be come free. next there are 3 screws holding in the ac panel thing, just remove them and disconnect everything from the back of that (just pull the vacuum hoses off and you have to disconnect the metal rod going to the hot/cold knob) once the ac panel is out you have to remove the back panel thing which is just held on by 6 clips i think. Next you will see the globe holders all you need is a small flatblade screwdriver and the holders will come out.
    hope that helps, you should be able to find the special globes at either a decent cap parts shop or you could get them straight from holden
    Sep 2009
    Rooty Hill
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    This thread below might help you out .
    Its got some photos of removing console. might help, may not
    I was looking at it the other day
    I have a job ahead of me to replace the same globes you are aswell
    also to find a vacuum leak in the dash.
    How to - Heater Core Removal and Hoses Photos Thread
  1. vp L3 dash cluster globes
    By nudge701 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-05-2010, 12:06 PM
  2. [VIC] dash cluster globes vx
    By ruggj in forum Swap / Wanted to Buy / Trade
    Last Post: 07-06-2009, 10:57 AM
  3. replacing globes
    By higgmont in forum General Discussion
    Last Post: 16-05-2009, 11:59 AM
  4. replacing standard dash cluster
    By vy02nv in forum Electrical Wiring / Questions
    Last Post: 14-04-2009, 09:55 PM
  5. Need help changing green globes to blue globes in instrument cluster
    By GILLO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 10:40 PM
