Results 1 to 19 of 19
Thread: IRS - camber adjust kit, i'm confused !! need help please...
    VT
    Jul 2010
    Central Coast, NSW
    Default i'm confused !! need help to choose camber kit
    Hi guys,
    i'm getting my VT sedan lowered and need to get camber kit sorted as the same time.. so, according to Nolathane website.. they are 4 different types you can buy...
    - IRS - toe adjust kit (46138HD) Single bolt - large offset suits inner pivot only use with 46138X for Camber & Toe adj
    - IRS - camber adjust kit (46138X) Single bolt camber adj, extra large offset outer pivot only use with 46138HD
    - IRS - toe adjust kit (46138A) 2 bolt design fit to inner pivot only
    IRS - camber/toe adjust kit (46138A) 2 bolt design fit to both inner and outer pivots (needs 2 set of this)
    so, what kit do i need? gonna have SSL kings at the rear
    Thanks in advance
    VT
    Jul 2010
    Central Coast, NSW
    VT S2 "S"
    Oct 2009
    Carrum Downs
    Depending on what rims you are running. I have 20" and have mine lowered on SSL's. I can't use a camber kit as it will drive the tyres into the guard. If i correct the camber, I would need to roll the guards. Food for thought.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    why wouldent you get the ppl who are lowering your car to order them
    i personaly would use the third down on the inner pivots and use pedders rubber outer kits
    VT
    Jul 2010
    Central Coast, NSW
    because, i'm going to do it myself and going to order it from one of the auto shop
    cheers
    vr berlina
    Aug 2010
    australia
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    get 2x the bottom ones, you have 4 pivot points on your IRS. 2 inner and 2 outer. if you purchase 1 kit (2 pivot points) you will either get camber OR toe, depending where you place it. by purchasing 2 of the kits, you can get both camber AND toe giving you the the most adjustment on general camber/toe issues. now if you have massive camber, your best to get 1 of each of the top 2 kits. this will give you the maximum possible amount of adjustment.
    hope that makes sense.
    vr berlina
    Aug 2010
    australia
    ahh mate using two of the top ones will if that low to need them will #### the the drive shafts and diff seals
    there is a reason why i said to use soild outer camber kits and adjustable inners due to the outer is the camber pivot so you just set it to max with the unjustable outer and the put the adjustable on the inner if you dont get under 1deg then dont worry at least it wont #### any thing
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    bottom ones, camber and toe, in and out up and down. you will need it to get the wheels as correct as possible. book a wheel allignment for the day after or soon after you do it so they can get the wheels spot on.
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    VT
    Jul 2010
    Central Coast, NSW
    Quote Originally Posted by ephect View Post
    Hi Champ, thanks for all the info and that made a lots of sense to me
    i'll try to get more info on this and see if i really wanna do it myself tho ..
    anyone know or heard or had any experience with superpro kit ?
    vr berlina
    Aug 2010
    australia
    i install them for a living i would only use super pro in one or two spots in my car and install nolathane so you would expect me to say nolathane all the way the superpro would be used in the front of the car so stay with nolathane in the back
    VT
    Jul 2010
    Central Coast, NSW
    Quote Originally Posted by vr1uz-fe View Post
    can you explain abit more? so, you would not recommend superpro kit? i should stay with Nolathane then? so, i need to get 2 x 46138A right ?
    so, you do this for living? wanna do it for me? lol
    how hard? do i need any special tools? or any tips?
    vr berlina
    Aug 2010
    australia
    well there is a special tool but is not needed unless doing the soild rubber outers but most mechanics have trouble doing camber kits
    yes go the two ones stated you can drill holes in the bushes the hit them out but it still takes ages to do
    i can lower a ve in 40mins but these still take me 1 & 1/2 hours to 2 to do a bloke who i used to work with could do the ve in 29 mins but the irs kits took him like 45mins and he holds the record for lowering a ve he can also do a vz in sixteen mins so how long dose it take you to lower a car triple that to do the camber kits
    VT
    Jul 2010
    Central Coast, NSW
    Gee! .. sound too hard to me already, lol
    where do you work? i might take mine there, i need someone who know what they doing and had experience
    how much you guys charged if i bring the kits?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As an example, I do the Super Pro 4 point kits for $175 posted.
    Visit my Facebook page
  16. #16
    vr berlina
    Aug 2010
    australia
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, I'm a wholesaler. And I said posted not fitted...lol
  18. #18
    VX SS T56
    Feb 2006
    I recently fitted super pro kit to my rear end.
    I put in both the inner and outer bushs. Each arm has one inner and one uter bush, so 4 in total.
    If you are doing it yourself, its a pretty hard job. You have to cut the outer bush bolt out, then trying to get the OEM bushs out is a nightmare. I ended up using an oxy welder to just melt them out.
    Then once you do have the new bushs in, trying to line them up with the brackets on the car body is bloody hard by yourself.
    I would give yourself at least a day each side, taking it slow. The higher you can jack your car, the better as it gives you room to move around under the car.
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
  19. #19
    VT
    Jul 2010
    Central Coast, NSW
    Shit, by the sound of it.. i won't do it myself to..
    can anyone recommend me a good susp shop around central coast areas or syd areas?
  1. Adjust bonnet on VP
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2012, 03:52 PM
  2. 93 vp. How do i adjust idling please
    By superslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2009, 05:22 PM
  3. How do I adjust the headlights on my VT
    By louie_the_fly in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2006, 10:28 PM
  4. adjust the clock?
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-03-2006, 08:43 PM
  5. How To Adjust The Handbrake
    By t3zza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2004, 04:58 PM
