Results 1 to 4 of 4
Thread: vx ecotec motor knocking at 2000rpm???
    VX Wagon
    Aug 2010
    Default vx ecotec motor knocking at 2000rpm???
    hey guys i bought a 2002 vx acclaim about 4 months ago with 190,000k's on it. misses dad looked over car when i got it his been a machanic all his life he said its good to buy been serviced every 10,000km then a few weeks ago i could hear a knocking noise when driving. Its the same when its cold and at normal temp it only comes in at 2000rpm idles smooth not missing ect. been to a few work shops and its coming from passenger side at rear of the motor there hinting bearings or piston slap. has anyone heard of this before?
    VR 5L ute
    Oct 2007
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Piston slap is usually worse when a motor is cold. I would be taking the sump off to have a look because a crook bearing could seize and punch the conrod out through the side of the block. It could also be the starter motor making the noise. Sometimes the starter gear can stay out so it is running on the ringear constantly and it will eventually wear out and make a knocking noise.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    If you can, fit an oil pressure gauge into the main gallery and see what is happening. If it is a loose rod shell, the idle pressure will drop off dramatically when the oil is hot.
  1. vx commodore knocking at 2000rpm help
    By Cameronvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2010, 10:10 AM
  2. [VIC] wtd- ecotec motor
    By jenkos_vl in forum Swap / Wanted to Buy / Trade
    Last Post: 15-02-2009, 01:13 PM
  3. Motor knocking - Alloytec 6
    By MrCalais in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-05-2008, 01:52 PM
  4. WTB: ECOTEC MOTOR! [Vic]
    By HoZy in forum Swap / Wanted to Buy / Trade
    Last Post: 28-09-2006, 02:45 PM
  5. motor knocking
    By medz84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 09:05 AM
