Hi PPl urgently seeking help my VX died it has no spark.. took it holden said that fault codes come from Cranks anngle sensor and DFI module... replaced Both with Brand New Ones and now check to see spark and still no luck.. whats next is there fuses i can check or anyother tests i can do.. already used the the search button but cant find anythin past replacing the CAS and DFI
Help Will be very appreciated... Holden wanter 1100 to fit both parts so did it myself for less than 200
There is a 15 amp fuse on the wire that supplies power to the DFI module. I think it is in the fuse box under the bonnet.
