Results 1 to 5 of 5
Thread: can some one tell me where the valley is
    vy calais .vs commodore
    Sep 2005
    blacktown
    Default can some one tell me where the valley is
    gday i have a problem with my radiator i am getting oil mixing with coolant i just had it looked at and my mecanic told me it could be the transmition leaking into the radiator or it could be the valley i would like to know what is the valley thanks
    dylanstone's Avatar
    dylanstone is offline tsu tsu tsu tsu
    3.8L 1997 VT executive
    Feb 2010
    sydney, eastern suburbs
    i hear when you get oil mixing with your coolant you have a blown head gasket......sorry no info on "the valley" just my two cents
    * 1997 VT executive
    * 2.5 inch Lukey catback
    * Lowered on Munro shocks Pedders springs
    * Fusion 1000 watt amp & Kenwood 12 inch sub & head unit
    00 SS M6/79 chev Monza
    Mar 2005
    if your car is a v6 the inlet manifold bolts on to the "valley" so if the valley gaskets need changing you remove your manifold ,change gaskets then re bolt your manifold back on .........allow a few hours to actually do the job !
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The valley is the part between either cylinder head, its called a valley because its shaped like one with the intake manifold removed.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    well the valley is actually the space between the cylinder banks on all v engines it is where the lifters sit in there bosses and the cam and gallery sit under the valley in the v6 the balence shaft runs over the valley and under the manifold the valley also cathches oil and drains it back over the cam which then falls down the timming cover at the front of the engine to end up in the sump
  1. does a vn valley cover fit a vr 3.8 v6
    By peckzz in forum General
    Last Post: 23-02-2010, 08:33 PM
  2. Valley cover gasket!!
    By AttaBoy in forum General
    Last Post: 17-06-2008, 09:41 PM
  3. Valley Cover Leak
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-05-2008, 04:18 PM
  4. air plenum-valley cover.
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2008, 10:47 PM
