hey everyone!
recently (tonight actually) my car overheated quickly and then returned back to just underhalfway on the temperature gauge.
spoke to a mate mechanic mate about it and he said not to check the dipstick untill tomorrow when the car is cold so i decided to put the car in the garage and leave it there overnight.
however upon walking inside i see a puddle on the drivers side of the car where it was parked before i put it away.
it smells kinda wierd and is clear/slightly green dont really know if it is coolant/oil/water?
is this bad? and can someone help me!
Green = coolant.
Check the coolant in the radiator (when its cold). You may have to add some, so you don't over heat it again when you take it for repair.
Possibly a faulty thermostant, seeing how the temp came back down.
would that cause it to leak but?
Have you looked over the motor for the leak?
Check hoses, welsh plugs and water pump among others.
Could be a cracked heater tap if the leak is on the drivers side
is there a way to check if its a heater tap?
i have the same problem with my vt and also sometimes when i accelerate it makes like a water rushing noise over my dash near my speedo? very weird anyone know the problem?
